If problem states acceleration is constant what is the acceleration?
The discussion revolves around a kinematics problem involving a bike rider experiencing constant acceleration while gliding down a hill. The rider's final velocity, time, and displacement are provided, and participants are exploring how to determine the acceleration from these variables.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to use kinematic equations that relate acceleration, initial velocity, final velocity, time, and displacement. There is uncertainty about how to handle the unknown initial velocity and the implications of assuming it to be zero.
Some participants have suggested writing down relevant kinematic equations and plugging in known values to find acceleration. Others have pointed out the challenge of having two unknowns and the potential for using substitution or elimination methods. There is an ongoing exploration of the assumptions regarding initial velocity.
Participants are navigating the constraints of the problem, including the requirement to find acceleration without explicitly needing to determine initial velocity. The discussion reflects a mix of assumptions and interpretations regarding the initial conditions of the motion.
survivorboiii
If problem states "acceleration is constant" what is the acceleration?
While gliding down a steep hill, a bike rider experiences constant acceleration. After 4.50 seconds, he reaches a final velocity of 7.50 m/sec. The bike's displacement was 19.0 meters.
I know that I'm supposed to be using one of the kinematics equations. But what do I put as acceleration when it says constant acceleration? What does variable a equal to?
t=4.5
vf=7.5 m/s
d= 19m
Find vi
You've got time, the final velocity, and the total displacement. What equation, which includes acceleration and initial velocity, would you use which contains all of these quantities?
If you write down this kinematic equation and start plugging in what you know, you should be able to determine what 'a' is.
Hint: This is why you study algebra in school.
There are two of them that includes all three given variables, but they also include acceleration and initial velocity, which I don't have. How do I solve for two unknown variables?
I just had the idea that the initial velocity would be 0 m/s
You have two equations and two unknowns. In algebra, this is where you would be using substitution or elimination, although there's actually an easier way to do this problem since one of the kinematic equations already contains only one of your unknowns.
Edit: I guess you actually only have one unknown, since you aren't required to find acceleration.
15K
16K
10K
