Calculate cos(θ/2) Given sin(θ)=-5/13
  • Thread starter Thread starter MathRaven
To find cos(θ/2) given sin(θ) = -5/13 and θ in the range π < θ < 3π/2, first calculate cos(θ) using the Pythagorean identity x² + y² = r², where y = -5 and r = 13. This results in x = ±12, leading to cos(θ) = -12/13 since θ is in the third quadrant. Then, apply the cosine half-angle identity, cos(θ/2) = ±√((1 + cos(θ))/2). Given the range for θ/2, determine the sign of the square root accordingly. The final result provides the value of cos(θ/2).
MathRaven
If sin(θ) = -5/13, π < θ < 3π/2, find cos(θ/2)
Given that sin(θ) = y/r, that we're in Quadrant III, and that x2 + y2 = r2, you should be able to find x, and from that, cos(θ).
Then use the cosine half-angle identity
\cos \left( \frac{\theta}{2} \right) = \pm \sqrt{\frac{1 + \cos \theta}{2}}
to find cos(θ/2). Since π < θ < 3π/2, you know the range of values that θ/2 lie in, so that will tell you whether the square root should be positive or negative.
You need to show some effort before we can help you.
Read the rules for this Forum.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
