Ignition Temp: Gasoline vs. Ethanol?
Gasoline has a lower ignition temperature compared to ethanol, with ethanol's ignition temperature being approximately 30 degrees higher. Despite this, gasoline has a higher energy content, ranging from 42 to 44 MJ/kg, while ethanol's energy content is about 26.68 MJ/kg. There is no direct correlation between ignition temperature and energy output upon combustion; gasoline's molecular structure, containing more C-C and C-H bonds, contributes to its higher energy release compared to ethanol. For further information on fuel properties, resources such as the General Table of Fuel Properties and combustion heat data can be consulted.
quasi426
Does gasoline have a higher ignition temperature then ethanol? (all other things being equal like pressure) Also does a higher ignition temperature mean that it will produce more energy upon combustion? Thanks in advance.
Science news on Phys.org
I think that the ignition temperature of ethanol is roughly 30 degrees higher than gasoline
But I do know that if one looks at the energy content in Nett MJ/kg on sees than ethanol has a value of 26.68, whereas gasoline has a value of 42 - 44. So gasoline has a higher energy content.
Regards,
Ben
To be sincere I don't know. Maybe you could find in a table the maximum adiabatic flame temperature of each substance. Also I think there is none general correlation between maximum adiabatic flame temperature and heat power released.
Another possibility is to ask to F.A. Williams, the combustion expert of your University.You know, in some class, hand up and ask, and then you tell me what he says to you. :biggrin: Do you know him?
I don't believe I know him. I am in the bioengineering dept. (undergrad). What department is he in?
He's in MAE and he is the director of the Center for Combustion Research.
At least, don't you know Prof. Lasheras?, the MAE chairman? He's an spanish aeronautical engineer.
