I How Does the GAIA Program Count 1.7 Billion Stars in Its Image?
  • I
  • Thread starter Thread starter nmsurobert
    Image Stars
The GAIA program counts 1.7 billion stars not by capturing traditional images but through a specialized optical system that collects data on various stellar properties. It uses CCD technology to convert detected photons into electrons, which are then processed to extract meaningful measurements. Most image data is discarded, and only significant information is transmitted to Earth for analysis by supercomputers. GAIA employs techniques like Time Delay Integration to enhance sensitivity, allowing it to track stars as they move across the sensor. This innovative approach enables the creation of a comprehensive database of stars and their characteristics.
nmsurobert
I just an read article on the ESAs Gaia program. I was wondering how they count the 1.7 billion stars in the image? Are the stars cataloged as the images are taken? Or is there a method that is used after the images have been collected?
http://sci.esa.int/gaia/60169-gaia-s-sky-in-colour/
Astronomy news on Phys.org
Other way around, GAIA don't really capture images in the traditional sense. The image is a visualization of the data captured by GAIA (position, radial velocity, proper motion, color etc.).
So when data is collected through the CCD camera, the data be turned into a graph... or something? ccds create images from potential differences, right? I am guessing the stars create potential differences and those can be counted?
GAIA's optical system, camera and data reduction is rather unusual and very specialized. It throws away most of the image data and only sends the interesting bits to Earth where it is processed by super computers that takes many measurements (on the top of my head around 80 or more) over several years of each star to build a database of stars (and some other objects) and their properties. There is a good primer article and video at:
http://sci.esa.int/gaia/53281-inside-gaia-s-billion-pixel-camera/
You are in the right neighborhood at least. Very loosely a pixel in a digital sensor (CMOS or CCD) is a tiny solar panel that turn every detected photon into one electron which it stores until it is ready to count them. Exactly how this is done depends on the technology used and especially the way the electrons are moved and read out of a CCDs pixels (the so called Bucket Brigade) give you several tricks to use. GAIA uses one of these tricks to do Time Delay Integration which gives it very good sensitivity even though the image of the stars trail across the senor as GAIA rotates:
https://en.wikipedia.org/wiki/Time_delay_and_integration
Likes Spinnor
ah ok. Thank you! This helps a lot.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
