Engineering Impedance angle in RL and RC circuits
The discussion centers on the phase angles of impedance in RL and RC circuits, specifically addressing the relationship between the impedance phase angle and the current phase angle. In an RC circuit with R = 5 Ohms and C = 100 microFarads, the total impedance is 27 Ohms at an angle of -79 degrees, while the total current is 370.5 mA at +79 degrees. In an RL circuit with R = 5 Ohms and L = 10 mH, the total impedance is 6.262 Ohms at +37 degrees, and the total current is 1.597 amps at -37 degrees. The current phase angle is the negative of the impedance phase angle due to the mathematical relationship defined by Ohm's law.
  • Understanding of AC circuit theory
  • Familiarity with Ohm's Law
  • Knowledge of impedance in RL and RC circuits
  • Basic complex number mathematics
  • Study the concept of impedance in AC circuits
  • Learn about phase relationships in RL and RC circuits
  • Explore the mathematical derivation of current and voltage phase angles
  • Investigate the effects of frequency on impedance in AC circuits
Electrical engineering students, educators teaching AC circuit analysis, and professionals working with alternating current systems will benefit from this discussion.
StuartSpencer
This isn't so much of a problem itself but I found it interesting that on the All About Circuits website, two of the questions give a phase angle for impedance as opposite the angle of current. I understand the current is 90 degrees out of phase with voltage in both RL and RC circuits, but do not understand the reasoning behind the impedance phase angles.
Here are the relevant links,
http://www.allaboutcircuits.com/textbook/alternating-current/chpt-4/series-resistor-capacitor-circuits/
http://www.allaboutcircuits.com/textbook/alternating-current/chpt-3/series-resistor-inductor-circuits/
V = IR [/B]
Not sure how to attempt a solution here, I looked online and used various searches but didn't find anything. If anyone could shed some light on this it would be appreciated.
Why don't you present one of the examples here for discussion so that helpers don't have to read through both pages to find what you're referring to?
Alright, in the RC circuit link there is an RC series circuit with
R = 5 Ohms
C = 100 microFarads
V = 10V / 60Hz
The total impedance is calculated to be 27 ohms and an angle of -79 degrees.
The total current is calculated to be 370.5 mA at an angle of +79 degrees.
In the RL circuit,
R = 5 ohms
L = 10 mH
V = 10V/ 60Hz
The total impedance is calculated to be 6.262 ohms at an angle of +37 degrees
The total current is calculated to be 1.597 amps at an angle of -37 degrees.
In both examples the current is the opposite angle of the impedance. Like I said I understand how the current differs in phase angle from the voltage, but do not understand where the relationship between phase angle of current and phase angle of impedance comes into play.
The current is given by Ohm's law:
##I = \frac{V}{Z}##
Since the voltage source is supplying the phase reference angle, it's angle is 0°. In the equation the impedance is in the denominator, so if its angle is, say Φ, when the division is performed the resulting phase angle of the current is given by 0° - Φ = -Φ. That's basic complex math.
Thank you very much, that clears it up for me!
11K
  • · Replies 46 ·
11K
