Improper integral, divergence/convergence
usn7564
Evaluate if the integral diverges or converges using the comparison theorem.
\int^ \infty_2 \frac{dx}{\sqrt{x^3+1}}
Having trouble with this question, the exercises I have managed I generally guessed if it was convergent/divergent, and then found a smaller of bigger function at the interval and went by that. Here I assumed it was convergent and used \frac{1}{\sqrt{x^2+1}}, though that was divergent which says absolutely nothing. Ran into the same issue with other attempts.
Is my reasoning the issue or have I just not found the correct manipulation? Not really approaching with anything more involved than "Find something bigger and hope it converges".
Any help would be appreciated, thanks.
It seems to me that a simpler comparison is x^3< x^3+ 1 so that \frac{1}{\sqrt{x^3+ 1}}< \frac{1}{\sqrt{x^3}}= x^{-3/2}.
I feel slightly moronic now, was too focused on manipulating the x term for whatever reason.
Thanks, glad I didn't get it all backwards at least.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
