Improper integral help: coloumb's law
Edwardo_Elric
i was deriving an infinite line of charge formula by coloumb's law:
so i got stuck with this integral (since it is in the maths forum)
\vec{E}_{\rho} = \int_{-\infty}^{\infty} \frac{\rho_L \rho dz}{4\pi\epsilon_o ({\rho}^2 + z^2)^{\frac{3}{2}}}
where
{\rho}_L = linear charge density
{\rho} = direction perpendicular to z axis in cylindrical coordinates
so when integrating (using trigo substitution):
\vec{E}_{\rho} = \frac{\rho_L\rho}{4\pi\epsilon_o} (\frac{1}{{\rho}^2} \frac{z}{p^2 + z^2})_{-\infty}^{\infty}
this is where i got stuck
no matter how i use lhopitals rule in this equation:
\lim_{z \infty} \frac{z}{({\rho}^2 + z^2)^{\frac{1}{2}}
it keeps going back
because the infinite is supposed to add to equate to 2
the answer which is
\vec{E}_{\rho} = \frac{\rho_L}{2\pi\epsilon_o\rho}
where
\vec{E}_{\rho} \frac{\rho_L\rho}{4\pi\epsilon_o} (\frac{1}{{\rho}^2} \frac{z}{p^2 + z^2})_{-\infty}^{\infty}
I think you need to show your work here. This is not at all what I got.
You don't need to use L'Hopital's rule- just divide numberator and denominator by z2. Of course, then the limits are both 0 which is not what you want.
it keeps going back
\lim_{z \to \infty} \frac{z}{({\rho}^2 + z^2)^{\frac{1}{2}}
the answer which is
I would prefer to change the limits of integration with each substitution.
yeah typo:
(\frac{z}{\sqrt{p^2 + z^2}})_{-\infty}^{\infty}
the problem is differentiating \sqrt{p^2 + z^2} when i keep using LHR it
keeps on going back
edit:
wait did you mean this?
\frac{\frac{z}{z}}{\frac{\frac{\sqrt{p^2+z^2}}{z^2}}}}
i tihink i get it now
just divide both sides by z
the denominator you divide by sqrt(z^2)
thx a lot halls
You say you used a trig substitution so why worry about the integral as a function of z at all? Change the limits of integration as you change the variable.
When I did it, my first substitution was \rho tan(\theta)= z. z will go to -\infty and \infty as \theta goes from -\pi/2 to \pi/2. I then integrated the resulting trig function by letting u= sin(\theta). While theta goes from -\pi/2 to \pi/2, u goes from -1 to 1 so I only had to evaluate the "u" formula between -1 and 1 without having to go back to the original variable.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
