Improving my engineering mathematics
Improving engineering mathematics involves focusing on the understanding of processes rather than memorizing specific equations. Reading each equation in detail can be beneficial, but it is crucial to grasp the derivation and significance behind them. The emphasis should be on understanding the simplifications made by authors and identifying key variables. Knowledge of complex equations is less important than comprehending how mathematics is applied in engineering contexts. Ultimately, understanding the application of math will enhance engineering skills more effectively than rote memorization.
MechEng2010
Hello all,
I am very much interested in improving my engineering mathematics and have one specific question.. When you are reading papers and books which lay out mathematics do you read each equation, symbol, etc and does this help you to understand the mathematics and engineering better? Thanks.
Any input on this anyone? Thanks.
Reading equations only helps if you understand what they are deriving. Specific equations aren't the most important thing (and to be honest, most of those complex equations are generally not necessary to know, you can always look them up if you need them). The thing that helps is understanding the process that the equation went through. What did the author start with, what did he do to simplify and why, what variables are the most important, and which are insignificant. Studying the math about the dispersal pattern of a specific flower's pollen will not make you a better engineer. But understanding how math is used will.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
