Impulse function applied to RLC circuit
The discussion centers on the application of the impulse function to a series RLC circuit, specifically analyzing the current i(t) at time t=0+. The author references a voltage source Vo*delta(t) and questions how the current can be Io = Vo/L given the instantaneous voltage change. A key point raised is the misunderstanding of the inductor and capacitor behavior at this moment; the inductor acts as a short circuit while the capacitor behaves as an open circuit. To resolve the confusion, it's suggested to derive the current by writing the differential equation and integrating it between the intervals of 0- and 0+. Understanding these principles is crucial for accurately analyzing RLC circuits under impulse conditions.
marc.orr
Hello, I've been reviewing some material from my undergraduate studies. In the book "Signals and Systems" by Haykin in the first chapter he gives an example of a voltage source with the value of Vo*delta(t) applied to a series RLC circuit.
Vo is some arbitrary constant and delta(t) is the impulse function. The question is what is the value of the current i(t) at time t=0+ where 0+ is at 0 looking from the more positive side of time.
He says the answer is (without any sort of derivation) Io = Vo/L. How is this possible? I figure that as there is an instantaneous change in voltage, the inductor will look like a short circuit and the capacitor will look like an open circuit. So how can there be any current flow?
Thankyou in advance.
Marc
You have this reversed.
If you write the differential equation and integrate it between 0- and 0+ you can find Io.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
