Why Is the Change in Momentum 8Ns Instead of -8Ns?
  • Thread starter Thread starter thoradicus
    Direction
The change in momentum of the ball is calculated using the formula momentum = mass * velocity, resulting in a value of 8Ns when considering direction. The confusion arises from the sign of the velocities; the initial velocity is positive and the final velocity is negative due to the ball reversing direction. It's clarified that impulse is a vector quantity, and thus both -8Ns and 8Ns can be correct depending on how the directions are defined. If the question specifies magnitude, the positive value should be used. Clear definition of positive and negative directions is essential for accuracy in such calculations.
thoradicus
A cricket bat strikes a ball of mass 0.16 kg traveling towards it. The ball initially hits the bat at a speed of 25m/s and returns along the same path with the same soeed. Time of impact is 0.003s
a)Determine change in momentum of the ball
b)Determine FOrce exterted on the ball
a) momentum=mass*velocity
b)Ft=mv-mu
What I am trying to ask is, given that v is negative to due to the ball returns in opposite direction, and u is positive then, shouldn't the awnser be: (.16)(-25)-(.16)(25)= -8Ns.
However, I am confused when the answer shows that it is 8Ns. Why is it so? Does questions like this account for magnitude only? O.o
Is it still correct if i put -8 as the awnser?
Impulse is a vector quantity which is why you have you get the answer -8Ns as opposed to +8Ns.
You could just define the initial velocity, u to be in the negative direction and the final velocity, v to be in the positive direction. That way you would get 8Ns.
If the question asks for the magnitude of impulse then you take the positive value. As long as you clearly define which direction is positive and which is negative, your answer is correct.
thanks
