Impulse/Momentum ball into wall Problem
  • Thread starter Thread starter adorrkable
    Ball Wall
A 0.1 kg ball rolling at 0.5 m/s reverses direction upon hitting a wall, resulting in a change in momentum of -0.1 kg m/s. The impulse exerted on the ball by the wall is equal in magnitude and opposite in direction to the impulse the ball exerts on the wall, confirming Newton's third law. Although the wall's momentum change is negligible, it still reacts to the impact, which is not significant for the problem's calculations. The impulse delivered to the wall is therefore 0.1 kg m/s. The discussion clarifies that the impulse applied to the ball equals its change in momentum, reinforcing the principles of impulse and momentum.
adorrkable
1) A 0.1 kg ball is rolling across the floor at 0.5 m/s when it hits a wall and reverses direction without any change in speed.
A) Can you determine the impulse delivered to the ball by the wall? If so, what is it? If not, explain why not.
B) Can you determine the impulse delivered by the ball to the wall? If so, what is it? If not, explain why not.
C) Can you determine the force exerted by the wall on the ball? If so, what is it? If not, explain why not.
Jnet = \Deltap
p = m*v
J = Fnet * \Deltat
My problem - I managed to calculate that the change in momentum for the ball is -0.1 m/s, but if this is the amount of impulse it exerts on the wall (since Jnet = Δp), wouldn't the wall exert an equal and opposite impulse? But wouldn't the wall's momentum and therefore change in momentum be zero, because Δp = m * Δv, and the wall never has any velocity.
Hi adorrkable,
Jnet = \Deltap
p = m*v
J = Fnet * \Deltat
Not to be picky, but remember the units are kg m/s.
Actually that's the impulse the wall exerts on the ball. When you apply:
<br /> \mbox{impulse} = \Delta p<br />
the two sides of the equation have to be applied to the same system. But yes, the impulse from the wall on the ball is equal in magnitude and opposite in direction from the impulse of the ball on the wall.
We wouldn't say that the no part of the wall never has any velocity, it's just that it's small enough to be ignored here. The wall will react in some way to the impact, but it's not important to the problem.
So the ball exerts an impulse of -0.1 kg m/s, and the wall exerts an impulse of 0.1 kg m/s, am I correct?
Thank you very much!
If the ball's change in momentum is -0.1 kg m/s, then that is what happened to it; and so the impulse of -0.1 kg m/s is what was applied to the ball (and the negative of that is what the ball applied to the wall).
That's what I meant about the equation; if you're looking at the ball as your system, then:
(impulse applied to ball)=(change in ball's momentum)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
