In the middle of an AC analysis problem, I am stuck -
The discussion revolves around solving a complex number equation for the current i_L in an AC analysis problem. The user initially arrives at an incorrect answer by misapplying complex number division rules, specifically by incorrectly splitting the fraction involving a complex denominator. Another participant clarifies that the correct approach is to multiply by the complex conjugate of the denominator, which simplifies the expression and leads to the correct result. The user acknowledges the mistake and gains a clearer understanding of how to handle complex fractions in this context. The conversation highlights the importance of proper techniques in complex number calculations for accurate results.
VinnyCee
OK, I have this complex number equation:
5\,V\,=\,\left[\left(j2\,+\,1\right)\,\left(1000\,-\,j10000\right)\,+\,\left(200\,+\,j2000\right)\right]\,i_L
Now I try to solve for i_L:
i_L\,=\,\frac{5\,V}{\left(j2\,+\,1\right)\,\left(1000\,-\,j10000\right)\,+\,\left(200\,+\,j2000\right)}
i_L\,=\,\frac{5\,V}{-20000j^2\,-\,6000j\,+\,1200}
Since j^2 is just -1:
i_L\,=\,\frac{5\,V}{21200\,-\,6000j}
And since \frac{1}{j} = -j, the final complex numbered answer I get is:
0.0002358\,+\,0.00083333j
However, this is incorrect! I have the answer for the problem, step-by-step, given by the prof. and I have double checked the answer using the Symbulator for the TI-89.
I should be getting:
0.00021836\,+\,0.0000618j
What am I doing wrong?:frown:
i_L\,=\,\frac{5\,V}{21200\,-\,6000j}\;\;\; (1)
0.0002358\,+\,0.00083333j \;\;\; (2)
What've you done to get from (1) to (2)? I would first divide top and bottom by 5 to get
i_L\,=\,\frac{V}{4240-1200j}
Now, you need to get this into the form V(x+jy), so I would multiply top and bottom by the complex conjugate of the denominator
i_L\,=\,\frac{V}{4240-1200j}\cdot\frac{4240+1200j}{4240+1200j}
Now expand out the denominator, and you should obtain a purely real number, and the result will follow from dividing the real and imaginary parts of the numerator by the denominator.
That's what I get too!
Wow, thanks!
Why does the way I was trying not work?
\frac{1}{j}\,=\,-j <----- Right?
\frac{5}{21200}\,=\,0.0002358
and for the complex part:
\frac{5}{-6000}\m\left(-j\right)\,=\,0.000833j
That is where I get the answer I was getting (wrong):
0.0002358\,+\,0.000833j
VinnyCee said:
Wow, thanks!
Because you made the error of assuming that \frac{a}{b+cj} = \frac{a}{b}+\frac{a}{cj}. This is not true (in general) and you cannot split up a fraction like this.
The trick for solving such a question is to always multiply the fraction by the conjugate of the denominator-- this makes the denominator real, and so the fraction becomes one of the form \frac{a+bj}{c} which of course can be simplified to obtain \frac{a}{c}+\frac{b}{c}j
Sweet, thanks again! Now I understand.
