Incident Angle Limitation Derivation in Optical Fibre
In summary, Snells Law states that the angle of reflection of a light ray is the sum of the angles of incidence and reflection. When solving for this angle, it is helpful to know the critical angle, which is the angle at which internal reflection occurs.
Eats Dirt
92
derive the angle of limitation sinθ=[(n2^2-n3^2)^1/2]/n1
n1 is the air out side of the fibre
n2 is inside of the fibre
n3 is the fibre wall
Snells Law:
n1sinθ1=n2sinθ2
I'm pretty stuck and don't really know where to go after getting the angles from geometry. I have pi/2-θ2 for the angle of reflection off of the optical wall. So I put this angle into Snells Law then just kind of get stuck.
First (for those of us unfamiliar with this topic), please describe the path of the light rays of interest. Better still, provide a diagram.
Snells Law:
n1sinθ1=n2sinθ2
Not quite.
When you have that corrected, use it at both the point of entry and at the point of internal reflection. (What is the minimum angle of incidence to get internal reflection? )
Connect the two using cos2 = 1 - sin2.
Likes 1 person
Snells Law: n1Sin(θi)=n2Sin(θt) where t is the transmitted and i is the incident ray and their angles are measured relative to the normal of the surface.
Ok I think I've got it,
[tex]\sin\theta[/tex]
[tex]n_1\sin\theta_i=n_2\sin\theta_t[/tex]
Known that the critical angle is [tex]\arcsin(\frac{n_2}{n_1})[/tex]
[tex]\arcsin(n3/n2)=\frac{\pi}{2}-\theta_2[/tex]
[tex]\theta_2=\frac{pi}{2}-\arcsin(\frac{n3}{n2})[/tex]
[tex]n_1\sin(\theta_i)=n_2\sin(\theta_2)\\
n_1\sin(\theta_i)=n_2\sin(\frac{pi}{2}-\arcsin(\frac{n_3}{n_2}))\\[/tex]
use the identity [tex]\sin(A-B)=sinAcosB-cosAsinB[/tex]
[tex]
n_1\sin(\theta_i)=n_2\sin(\frac{pi}{2})\cos(\arcsin(\frac{n3}{n2}))[/tex]
use the identity [tex] \cos(\arcsin(x))=(1-x^2)^\frac{1}{2}\\
n_1\sin(\theta_i)=n_2(1-(\frac{n_3}{n_2})^2)^\frac{1}{2}\\
\sin(\theta_i)=\frac{n_2}{n_1}(1-(\frac{n_3}{n_2})^2)^\frac{1}{2}\\
\sin(\theta_i)=\frac{1}{n_1}((n_2)^2-(n_3)^2)^\frac{1}{2}[/tex]
Thanks for your help haruspex!
Converted to LaTeX for easier reading :wink:
##n_1\sin(\theta_i)=n_2\sin(\theta_t)##
Known that the critical angle is ##\arcsin(\frac{n_2}{n_1})##[general case]
so ##\arcsin(\frac{n_3}{n_2})=\frac{\pi}{2}-\theta_2##
##\theta_2=\frac{pi}{2}-\arcsin(n_3/n_2)##
##n_1\sin(\theta_i)=n_2\sin(\theta_2)##
##n_1\sin(\theta_i)=n_2\sin(\frac{\pi}{2}-\arcsin(\frac{n_3}{n_2}))##
use the identity ##\sin(A-B)####=####sinAcosB-cosAsinB##
##n_1\sin(\theta_i)=n_2\sin\frac{\pi}{2}\cos(\arcsin(\frac{n_3}{n_2})##
use the identity ##\cos(\arcsin(x))=(1-x^2)^\frac{1}{2}##
##n_1\sin(\theta_i)=n_2(1-(\frac{n_3}{n_2})^2)##
##\sin(\theta_i)=\frac{n_2}{n_1}*(1-(\frac{n_3}{n_2})^2)##
##\sin(\theta_i)=\frac{1}{n_1}*((n_2)^2-(n_3)^2)^\frac{1}{2}##
I edited my earlier message to convert it to latex :) took me a while as I have only used it a few times prior.
Related to Incident Angle Limitation Derivation in Optical Fibre
What is an incident angle limitation in optical fibre?
An incident angle limitation in optical fibre refers to the maximum angle at which a light ray can enter the fibre without experiencing total internal reflection. This limitation is determined by the refractive index of the core and cladding materials of the fibre.
How is the incident angle limitation derived in optical fibre?
The incident angle limitation in optical fibre can be derived using Snell's law, which relates the angle of incidence and angle of refraction of a light ray passing through two different materials. By setting the angle of refraction to 90 degrees, we can determine the critical angle at which total internal reflection occurs, which ultimately determines the incident angle limitation in the fibre.
What factors affect the incident angle limitation in optical fibre?
The primary factor that affects the incident angle limitation in optical fibre is the refractive index of the core and cladding materials. A higher refractive index leads to a smaller incident angle limitation. Other factors that may impact the limitation include the shape and size of the fibre, the wavelength of light, and any external conditions such as temperature or pressure.
Why is it important to understand the incident angle limitation in optical fibre?
Understanding the incident angle limitation in optical fibre is crucial for designing and using optical fibre systems effectively. If the incident angle exceeds the limitation, total internal reflection will not occur, resulting in signal loss and decreased efficiency of the system. By knowing and accounting for this limitation, we can ensure optimal performance of optical fibre systems.
How can the incident angle limitation in optical fibre be overcome?
There are a few ways to overcome the incident angle limitation in optical fibre, including using materials with a higher refractive index, using a larger fibre core, or using special coatings or structures to reduce the effect of external conditions. However, these solutions may also have drawbacks, such as increased cost or complexity, so it is important to carefully consider the specific needs of the system before attempting to overcome the limitation.
