Increasing Induced Current in Mutual Induction
To increase the induced current in mutual induction without raising the electromotive force (EMF), lowering the resistance of the conductor is suggested, as per Ohm's Law (V=IR). Reducing the number of turns in the coupled circuit can also lead to a higher current since a decrease in EMF results in an increase in current. Additionally, increasing the number of coils in a solenoid or toroid can enhance the magnetic field interaction, potentially boosting the induced current. The discussion emphasizes the balance between EMF and current in the context of mutual induction. Overall, various methods can be employed to manipulate induced current effectively.
phyphysics
In mutual induction, how can we increase the induced current, not e.m.f.?
Do you mean increase the induced current WITHOUT a corresponding increase to EMF? Lower the resistance of the conductor?
theres just v=ir, after all...
Reduce the number of turns in the coupled circuit. As the emf goes down, the
current goes up.
increase the number of coils if its going through a solenoid or toroid
Increase the number of turns of the induced coil?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
