Indefinite Integral of a contant function
rambo5330
This question is bugging me
if an indefinite integral is of the form F(x) + C
stating that F(x) is an antiderivative of f(x) and since the derivative of a constant is 0 the collection of all of the anti derivatives are of the F(x) + C accounting for the fact any constant can be tagged to the end of that anti derivative..
now if this were an initial value problem you can take F(0) = 10 and solve for C correct...
well why with a constant function say f(x) = 1 when I solve for indefinite integral of the form F(x) + C ... I get x + C
well if f(x) is a constant function then wouldn't f(0) = 1 f(5) = 1
but in each of these cases i get C + 5 = 1 therefore c = -4 or C + 0 = 1 therefor C = 1
but if this if F(x) + C is a general expression that allows you to find the area under a graph up to point x ... then
find the area under a function which is constant f(x) = 1 on interval [0,9]
should = 9
but x + 1 = 9 + 1 = 10 so its obvious to see that C should equal zero
where am I going wrong can someone please clear this up?
You seem to be getting confused as to what F(x) + C and f(x) are. f(x) is the function you're integrating, so yes C can be any constant in the end. It can even be 24937203. It doesn't matter. If you're trying to find the area of the function f(x) = 1 from 0 to 9 then you are no longer solving an INDEFINITE integral, now you need to set limits on your integrate and solve the DEFINITE integral.
For this case I'll just show you the result:
\int_{0}^{9}1dx = x + C|_{0}^{9} = (9 + C) - (0 + C) = 9 + C - C
So you see the C's will cancel out in the end, it doesn't matter what they are because when solving the definite integral that constant will ALWAYS end up cancelling out.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
