Indefinite Integration by exchange of variables
Asphyxiated
\int \frac {1}{\sqrt{x}(1+\sqrt{x})} dx
So let
u = 1 + \sqrt{x}
then
du = \frac {1}{2}x^{-1/2} dx
So dx should be this:
dx = 2x^{1/2} du
right?
So now the Problem looks something like this:
\int \frac {2\sqrt{x}}{\sqrt{x}(u)} du
\int \frac {\sqrt{x}}{(u)} du
I am stuck here, I am just not sure where to go from here, the answer is suppose to be:
2ln(1+\sqrt{x}) + C
but I really don't know how to get there.
thanks!
So let
u = 1 + \sqrt{x}
then
dx = 2x^{1/2} du
right?
2ln(1+\sqrt{x}) + C
thanks!
\int \frac {2\sqrt{x}}{u\sqrt{x}} du = \int \frac {\sqrt{x}}{u} du ??
\int \frac {2\sqrt{x}}{u\sqrt{x}} du = \int \frac {2}{u} du
haha right... so then the proper way to get to the answer is this then:
\int 2 * \frac {1}{u} du
then take an antiderivative:
2*ln(u)
2ln(1+\sqrt{x}) +C
is that right?
2*ln(u)
2ln(1+\sqrt{x}) +C
is that right?
Looks right to me.
ok can you help me on a problem of the same type?
\int \frac {3t+4}{5-t}dt
Let:
u = 5 -t
du = -1 dt
dt = -1 du
\int -\frac {3t+4}{u} du
so here I am kind of guessing..
\int -(3t+4)* \frac {1}{u} du
\int (-3t-4) * \frac {1}{u}du
\int -3t\frac{1}{u}-4\frac{1}{u}
I don't think I am on the right track here though, the correct answer is
-3t -19ln(5-t) +C
and I don't see how to get there from here, its probably just something I am not seeing again... thanks in advance
Let:
u = 5 -t
du = -1 dt
dt = -1 du
-3t -19ln(5-t) +C
u = 5 -t so
t = 5 -u
3t + 4 = 3(5-t)+4 = 19 -3u
Try to figure it out from there. Hint: split into 2 integrals. You have basically right idea, you just need to get that t in terms of u somehow so you can actually integrate.
ok so starting from the point of
\int (-19+3u)*\frac{1}{u} du
note that I just applied the - sign throughout, that's why my signs are different than yours
so my next guess would be here:
\int -19\frac{1}{u} + 3u\frac{1}{u} du
so then I am assuming I can like so:
\int -19\frac{1}{u} + 3u\frac{1}{u} du = \int -19\frac{1}{u} du + \int \frac {3u}{u} du
so I can see that the -19ln(5-t) comes out there but the integral of 3 du is 3u right? so 3(5-t) = 15-3t which does give me the -3t for the solution but the +15 ruins the answer... at least I think so...
I got the same answer as you and that looks right. The answer you got it:
y = 15 - 3t -19ln(5-t) + c_1
Let
c = 15 + c_1 \rightarrow y = -3t - 19ln(5-t) + c
The +15 is just a constant so it does not change the functional form of your answer. That is why you might as well absorb it into the c_1 so your answer looks nicer.
Wow I actually didn't know that, thanks man, I would have been thinking that over forever.
