Indefinite Trignometric Integral
The discussion focuses on solving the integral ∫sinxcos(x/2)dx as part of test preparation. The initial approach involves a substitution that leads to an expression using square roots, but discrepancies arise when comparing results with a graphing calculator. Participants suggest using trigonometric identities to simplify the problem and note an error in the final result related to the square root. Additionally, there is a conversation about using LaTeX for clearer mathematical notation in posts. The thread emphasizes the importance of accurate substitutions and the utility of LaTeX for presenting mathematical expressions effectively.
in the rye
∫sinxcos(x/2)dx
This isn't an actual homework problem, but one I found that I'm working on for test prep.
[/B]
∫sinxcos(x/2) dx = ∫sinx√((1+cosx)/2) dx
u = ½ + ½ cosx
-2 du = sinx dx
-2∫√(u) du = -2(2/3⋅u3/2) + c
-2(2/3⋅u3/2) + c = -4/3⋅[(1+cosx)/2)3/2] + c
-4/3⋅[(1+cosx)/2)3/2] = -4/3⋅(cos(x/2))3/2 + c
I tried to check my solution by graphing my answer with theirs, but the table is displaying different values.
in the rye said:
∫sinxcos(x/2)dx
[/B]
u = ½ + ½ cosx
-2 du = sinx dx
You have an error in the last line:
The formula you used for the substitution is ##\sqrt{\frac{1+\cos x}{2}}=\cos \frac{x}{2}##
Gotcha, so it's probably easier to leave it where I had it in the second line. For some reason the solution isn't working, still. Even when I just plug the integral on my graphic calculator. :/
Is there a trick to getting my square roots to look fancy like yours so I can clean it up when I post?
there's another way, I think it is easier. Remember the product to sum trigonometric identities? Use it!
Weird, I get the same result as you, except for the erroneous square root in the final result.
@MidgetDwarf 's suggestion is also good, but as said, you really are one symbol away from the solution.
Yes, I use ##\LaTeX##. It may look difficult if you never used it, but you'll learn it quickly. It makes posts with equations much more readable, and I highly recommend the use of it.
There is a guide here, there is also a link to that guide in the bottom left of the edit box.
If you see a complex ##\LaTeX## expression and want to see how it was composed, right-click the expression written in it and select "Show Math As -> TeX Commands". A small window will appear containing the code used for that expression. Or just quote a post: the ##\LaTeX## code will in general appear between ## or $$ tags.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
