I Is it Possible to Index a Cubic Lattice with h^2+k^2+l^2=7?
  • I
  • Thread starter Thread starter elevenb
    Cubic Lattice
elevenb
Hi everyone,
I've been given a problem where I have to index reflections from a cubic lattice, the procedure is simple enough but I'm getting a case where I get :
h^2+k^2+l^2=7
I've taken to many books, but most either don't mention the topic or say they are simply 'forbidden' reflections. I have also seen where I should double hkl before indexing but I haven't seen a concrete example of this.
I don't think irrational miller indices are the solution here either.
Any contribution would be so helpful.
I never did index a crystal, but the situation appears to be quite trivial. Specifically, I was looking at the table "Selection Rules for Reflections in Cubic Crystals" here
http://www.khwarizmi.org/system/files/activities/146/csd1.pdf
I suppose your substance is BCC. Then you don't observe the peak (100) with h^2 +k^2 +l^2=1, because it is forbidden for a BCC lattice. Instead, the first peak you observe is (110) with h^2 +k^2 +l^2=2. If you wrongly assign it as (100) , you will assign also the following peaks wrong. You don't realize this immediately, because all peaks with h^2+k^2+l^2 odd are forbidden, too. So you will assume for them with h^2 +k^2 +l^2=n instead of 2n. The first time you notice is with the peak (321) for which you obtain h^2+k^2+l^2=7 instead of 14, but 7 never occurs in any cubic pattern.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
10K
