Induced Current in a Coil with Changing Magnetic Field
The discussion focuses on calculating the induced current in a coil with a changing magnetic field. The coil has a diameter of 5.0 cm, 20 turns, and a resistance of 0.50Ω. The magnetic field is defined as B=0.020t+0.010t^2, leading to the expression for magnetic flux. The correct induced current expression is derived as I = (20πr^2(0.020 + 0.020t))/R, incorporating the number of turns in the coil. The final answer reflects the relationship between magnetic flux and induced current accurately.
BrainMan
A 5.0-cm-diameter coil has 20 turns and a resistance of 0.50Ω. A magnetic field perpendicular to the coil is B=0.020t+0.010t^2, where B is in tesla and t is in seconds.
Find an expression for the induced current I(t) as a function of time.
\varepsilon = \frac{d\phi}{dt}
\varepsilon dt = d\phi
\int\varepsilon dt = \int d\phi
\phi = (0.020t + .010t^2) * \pi r^2
\varepsilon \int dt = \int d\phi
\varepsilon t = \pi r^2 [ (1/2) (0.020t^2) + (1/3)(.010t^3)]
\varepsilon = \frac {I}{R}
I = \frac{\pi r^2 [ (1/2) (0.020t^2) + (1/3)(.010t^3)]}{tR}
OK, except you haven't taken into account that you have 20 turns in the coil.
Don't do this.
Use your expression ## \phi = (0.020t + .010t^2) * \pi r^2 ## in ## \varepsilon = \frac{d\phi}{dt} ## along with the correction for the 20 turns.
Likes BrainMan
TSny said:
OK, except you haven't taken into account that you have 20 turns in the coil.Don't do this.
So I = \frac{20\pi r^2 [ (1/2) (0.020t^2) + (1/3)(.010t^3)]}{R}
So like this?
So like this?
No. The numerator in your expression for ##I## does not equal ##\varepsilon##.
If ## \phi = (0.020t + .010t^2) * \pi r^2 ##, then what is ##\frac{d\phi}{dt} ##?
Likes BrainMan
Oh ok I get it now. The answer should be \frac {20\pi r^2(0.020+.020t)}{R}
Looks good.
Likes BrainMan
