- #141
sophiecentaur
- 6,906
??jsmith613 said:Ok so I think you are saying that the mean emf will be zero but the mean current WILL NOT BE otherwise the magnetic field would not be produced, right?
As far as I'm concerned, as long as you ignore inductance (which you can), the current flowing in the coil of the tube will be directly proportional to the EMF. Where have I given the impression that they don't precisely track each other?
If current is flowing one way (because the emf is causing it to) in one part of the tube and in another direction in another part of the tube (for the same reason) then the mean current is zero but that doesn't imply that the Force on the magnet will be zero, does it? The currents at either end of the magnet must flow in opposite directions or the effect on one of the poles would be to PUSH the magnet down.
Are you reading elsewhere about Induction, RH and LH rules etc.? It may be a good idea because I think you may be mis-reading what I am writing at times. If you read someone elses way of putting things then perhaps it will make more sense to you.
All this stuff is so basic that it is available to read about all over the net. Have you ever tried the 'Hyperphysics ' pages? They are very good. I usually find something there for pretty well every topic.
