Inductors & AC Circuits (Homework) (RL Circuit)
In a series RL circuit with a resistance of 7.0 kΩ, the inductance can be calculated using the time constant equation, Tau = L/R. Given that the current reaches half of its final value in 26 µs, the time constant Tau is determined to be 26 µs multiplied by 2 and then multiplied by 0.63212. This leads to the calculation of inductance (L), which is found to be approximately 0.2301 H. The discussion confirms the use of the time constant in solving for inductance in an RL circuit.
harkirat2009
What is the inductance in a series RL circuit in which R = 7.0 kΩ if the current increases to one half of its final value in 26 µs?
am i correct in assuming that i should be using the time constant equation: Tau=L/R
if i was correct in using this equation then:
Tau = ((26E^-6)*2))*.63212
R = 7000 Ohms
Tau*R=L
L=.23009168 H
e^{-t/\tau}=\frac{1}{2} for t = 26 µs.
thank you for your help
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
