Calculating Speed of Sports Car at Inelastic Collision
A 920-kg sports car collides with a 2300-kg SUV, resulting in an inelastic collision where both vehicles skid 2.8 meters before stopping. The discussion revolves around calculating the initial speed of the sports car using momentum conservation and frictional force. The force of friction is determined to be 25,244 N, which is used to find the deceleration and subsequently the initial speed. Participants emphasize the importance of using kinematic equations and conservation of momentum to solve the problem effectively. The conversation highlights the need to work backwards from the final state to determine the initial speed of the sports car.
ace123
A 920-kg sports car collides into a rear end of a 2300 kg SUV stopped at a red light. The bumpers lock, the brakes are locked, and the two cars skid foward 2.8 m before stopping. The police officer, knowing that the coefficient of kinetic friction between tires and road is .80 , calculates the speed of the sports car at impact. What was that speed?
This is all that I did before I got stuck.
I set up the conservation of momentum :920 kg * V_{1}= 3220 * V_2{}
Then I did F\Deltat= \DeltaP
I found the force to be 25244= 3220 V_{2} / \Deltat
Now is where I get stuck. I think I did something wrong because I'm pretty sure I need to do v/t =d.
Also not sure if I should use kinetic energy in this one since it's not conserved.
Any help will be great. Thanks as always.
On a side note: Isn't it hilarious how the officer knows the kinetic friction and calculates the speed.
For this problem you need to work backwards. You have equations of kinematics, from which you can calculate the inital speed of the two interlocked cars (remember that for any force, including friction, F=m*a).
After that you can used conservation of momentum (the fact that m1v1=m2v2) to calculate the initial speed of the moving car.
theUndergrad
http://www.theUndergraduateJournal.com/
why didn't I think of that. Thanks
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
