Rotational Dynamics of 2 Particles and 2 Rods
The discussion focuses on calculating the rotational inertia and kinetic energy of a system consisting of two particles and two rods rotating around a common axis. The particles each have a mass of 2.30 kg, while the rods have a mass of 0.360 kg and a length of 0.670 m. To find the total rotational inertia, it is suggested to consider each rod and particle separately, applying the parallel axis theorem where necessary. The parallel axis theorem is particularly relevant for the second rod, which does not rotate about the axis. The conversation emphasizes the need to sum the contributions from all components to arrive at the correct values.
cd80187
In Fig. 10-35, two particles, each with mass m = 2.30 kg, are fastened to each other, and to a rotation axis at O, by two thin rods, each with length d = 0.670 m and mass M = 0.360 kg. The combination rotates around the rotation axis with angular speed ω = 0.211 rad/s. Measured about O, what are the combination's (a) rotational inertia and (b) kinetic energy?
(I'm not sure how to post pictures on here, because the picture is on wileyplus, and to view it, you need a password)
But for this problem, I am not even sure where to start. I know that I need to find the total inertia, but how many parts should i split it into? Should I take each rod seperately and each particle seperately, and use the summation formula for inertia, or should i use the parallel axis theorem? I am just so lost on where to start.
If the configuration is axis-rod-particle-rod-particle, then you will want to use the parallel axis theorem for the rods and add the contributions from the masses. The parallel axis theorm has already been used for the rod rotating at one end in most places where you look up moments of inertia. Since the second rod is not touching the axis, you will have to compute it yourself.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
