What is the infimum of b - a for b>a?
  • Thread starter Thread starter Gavins
    Sums
Gavins
If b>a, find the infimum of b - a for arbritrary b,a.
So this is for a darboux sum but I'm stuck on proving that 0 is the inf. It seems really easy but I can't seem to think straight.
First thing is 0 is a lower bound of b - a.
b - a > 0
b > a
Next is to prove it's the greatest lower bound. I tried to do this by supposing x > 0 is the greatest lower bound and find some contradiction but I can't figure it out.
Ok, go ahead. Suppose x>0 is a lower bound. Pick b=x/2 and a=0. Is x a lower bound for b-a?
Does that not only prove it then when a = 0? I guess I might as well say what I'm doing. Basically, I'm trying to get the darboux sum for a function where f(x) = 1 if x = 0 and f(x) = 0 otherwise. I got the lower darboux sum and then when I try to do the upper darboux sum, I get \Sigma(xj+1 - xj)sup f. So if I expand this sum, I get 0 for every interval except the interval that contains 0 ie [xk,xk+1]. The upper darboux sum is xk+1 - xk. Clearly, the inf is 0 but I need to prove this.
Well, no. The assumption that was that x>0 was a lower bound of b-a for ALL b>a. If it's not a lower bound for SOME b>a, then x>0 is NOT a lower bound. But you are thinking about this way too generally. Of course you can make the upper sum as small as you want by picking x_(j+1)-x_j as small as you want. You might make the interval containing 0 be [-1/n,1/n]. So sure, you can make that as close to zero as you want by picking n large enough.
Thanks for that. Got it all sorted out now.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
