How to Determine Electric Field and Potential in an Infinitely Charged Plate?
  • Thread starter Thread starter dingo_d
    Charged Plate
dingo_d
Infinite plate is charged with symmetrically due to its central plane x = 0. Volume charge density is equal to \rho = \rho(| x |). Determine the electric field E and potential \phi within the panel. Take that the potential vanishes at points of the central plane.
The electric field:
\vec{E}(\vec{r})=\int\frac{\rho(\vec{r}')(\vec{r}-\vec{r'})}{|\vec{r}-\vec{r}'|^3}d^3r', and potential is
\phi(\vec{r})=\int\frac{\rho(\vec{r}')}{|\vec{r}-\vec{r}'|}d^3r'
What I'm having problem with is setting this up.
So I have an infinite charged plate, and I'm assuming it looks like this:
[PLAIN]http://img243.imageshack.us/img243/9877/73983825.png
And it goes to infinity in those directions. How to set up the coordinate system? Do I use some random point P away from the plate and look the E and \phi there or do I use the method of images?
I'm totally lost :\
I'd stick with Cartesian coordinates for it. Then use the differential form of Gauss' Law. \nabla\bulletE=\frac{\rho}{\epsilon_{o}}
Ok, but still I need to calculate the electric field, I could use \nabla\cdot\vec{E}=4\pi \rho but I'd still need to integrate it to get E...
Soo... Any help? :\
I think the point is that if you integrate along the x-axis you get \int\frac{\rho(x)}{\epsilon_0}dx\widehat{x}
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
