Infra red port for board camera
To create an infrared port for a board camera with RCA output, it's important to note that standard infrared ports cannot handle digitized video due to insufficient bandwidth. Users seeking to transmit video should consider alternatives that support higher data rates. The discussion highlights the limitations of inexpensive infrared technology for video transmission. A more suitable solution may involve using a different method or technology that can accommodate the required video quality. Understanding these constraints is crucial for successful implementation.
m718
Does anyone know how to make an infrared port for a board camera to transfer video to a pocket pc, the camera is analog with RCA output.
You won't be able to transmit digitized video over a cheap infrared port. The bandwidth is much, much too low.
- Warren
what kind of infrared port do I need?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
