Infrared spectroscopy of a cyclic alkene
The discussion centers on extracting limonene from orange peels and analyzing it using IR spectroscopy. Participants highlight the challenges of identifying ring structures in limonene, noting that while IR spectroscopy provides valuable information about functional groups, it is not definitive for determining cyclicity. Key spectral features include C-H vibrations around 2900 cm-1, C=C signals near 1600 cm-1, and O-H stretching around 3500 cm-1. The conversation emphasizes that limonene contains two double bonds and that its cyclic structure does not significantly alter the IR spectrum compared to non-cyclic hydrocarbons. To aid in analysis, users recommend consulting IR atlases for known spectra of limonene and focusing on the fingerprint region (400-1400 cm-1) for reliable comparisons. Overall, the discussion underscores the importance of combining IR spectroscopy with other methods for accurate structural determination.
asfd
At school we extracted limonene from orange peels and we had to make an IR spectroscopy for it but I don't see anywhere how we can know the product has a ring constitution... I see a lot of information about aromatic rings but nothing for an alkene ring... Can anybody help me?
Chemistry news on Phys.org
Well, if it is what you mean, you can find some useful sites by googling "limonene" and "IR". It has an alcohol group, an isopropyl chain (if I am not wrong), and one or two double bonds. So all of them can be seen in their corresponding regions; also look for multiple regions for different modes. For example, a C-H vibration of an alkane/alkene at ca. 2900 cm-1 always has more powerful C-H deformation at ca. 1400 cm-1, etc. You can see a C=C signal at around 1600 cm-1, and of course, alcoholic O-H stretching is around 3500 cm-1, where its C-O deformations are around 1200 cm-1.
Hope these help (don't forget to google).
As known IR spectroscopy is a support method to determine the sturucture, without being known what the sample is, IR is not solely enough...
In your example, limonene has two separate double bonds. These double bonds are ordinary sp2 hybrids, so the overall cyclic structure doesn't exhibit a very different spectrum. The movements in the bond change slightly due to the not-too-much-strain. But if the structure were something like cyclopropane, then we would expect a change than the normal sigma bond. This change would be assgined to the abnormal change in the angle for sp3 hybrid. (Normally 109,5 degrees). Actuallt, in the FTIR spectrum of cyclopropane, the signal about 3000 is broadand smears to about 3200, where in the non-cyclic hydrocarbons this is sharper and generally not exceed 3000.
Until now, what I wrote is a little off-topic, but this is to explain that only IR spectrum is not a tool to determine the structure if it's cyclic or not... Assuming that the sample is unknown, you should consult additional methods to determine "cyclicity". I hope I explained clearly.
Thank you for the informations
Well one method might be to find the known IR spectrum of limonene and compare it your results.
So-crates, you are a genius :smile: You reminded me that there are IR atlases, and one of them must have an entry for limonene. asfd, if you are a university student, your library must have an IR atlas, in which you very likely find the IR of limonene and as so-crates said, compare them. Remember that only the range between 400 (or lower such as 100) and 1400 cm-1 is reliable in terms of comparison, since this is well known as "fingerprint" region, where only the same molecules can give the same pattern.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
9K
10K
9K
61K
