Initial Value Differential Equations problem
5 replies · 5K views
Chandasouk
dy/dt = 2y-5, y(0) = y_0
The answer I got for this was y =5/2 + (y_0-5/2)e^t
but the solution is y =5/2 + (y_0-5/2)e^-2t
Where did this -2t come from?
My steps:
dy = (2y-5)dt Integrating both sides gives
1/2*ln|2y - 5| = t + C take exp of both sides gives
1/2(2y-5) = Cet
y-5/2 = Cet
solving for C
(y0) - 5/2=C*e0
C= y0 - 5/2
Both answers above are incorrect. Did you write the book's solution incorrectly? The correct solution isd be y = 5/2 + (y0 - 5/2)e2t.
My steps:
You're skipping some steps here. Here's what I did.
dy/(2y - 5) = dt
==> (1/2)dy/(y - 5/2) = dt (factoring 2 out of the denominator on the left)
==> dy/(y - 5/2) = 2dt
Now integrate, getting
ln(y - 5/2) = 2t + C
==> y - 5/2 = e2t + C = Ae2t, where A = eC
==> y = 5/2 + Ae2t
All that's left is to use the initial condition to solve for A.
1/2(2y-5) = Cet
y-5/2 = Cet
solving for C
(y0) - 5/2=C*e0
C= y0 - 5/2
Whenever you solve a differential equation, you should verify that your solution actually is a solution. If you had done that, you would have seen that neither the solution you found nor the one you said was "the solution" actually works.
I have misread the solution. The answer is y =5/2 + (y_0-5/2)e^2t
I would've never thought to factor out the 2 like you did though. I just integrated as
dy/(2y-5) = dt
Used U substitution for the integral on the left side of the equation.
U = 2y-5, du = 2dy, so du/2=dy
that gave me 1/2[tex]\int[/tex] du/u = [tex]\int[/tex]dt
e both sides
1/2(2y-5) = Cet
y-5/2 = Cet
solving for C
(y0) - 5/2=C*e0
C= y0 - 5/2
However I cannot get the 2t to appear as my exponent
dy/(2y-5) = dt
e both sides
1/2(2y-5) = Cet
You're making a mistake here (above). eu*v [itex]\neq[/itex] eu * uv.
Also, e1/2 [itex]\neq[/itex] 1/2.
Chandasouk said:
y-5/2 = Cet
solving for C
(y0) - 5/2=C*e0
C= y0 - 5/2
So when I e both sides of 1/2*ln|2y - 5| = t + C
it's should be
e1/2*eln|2y - 5| = e t + C
e1/2*2y-5=Cet
2y-5 = Cet/e1/2
2y-5 = Ce2t
Now I see where the 2t came from.
it's should be
NO! That's what I said in my previous post.
Starting with 1/2*ln|2y - 5| = t + C, the simplest thing to do is to multiply both sides by 2.
But
[tex]e^{1/2 * ln|2y - 5|} \neq e^{1/2}~e^{ ln|2y - 5|}[/tex]
which is what you're trying to do.
Chandasouk said:
e1/2*2y-5=Cet
2y-5 = Cet/e1/2
2y-5 = Ce2t
No you don't.
[tex]\frac{e^t}{e^{1/2}} \neq e^{2t}[/tex]
