Find Initial Velocity: Time = 2.58s, Distance = 9.87m
To find the initial velocity of a ball given a time of 2.58 seconds and a distance of 9.87 meters, the key equations involve understanding acceleration. There is confusion about whether acceleration is applicable, with suggestions that if the ball is falling, it would experience an acceleration of approximately 10 m/s². The equation x = x₀ + v₀t + ½at² is recommended for solving the problem. Clarification on whether the ball is in free fall or moving horizontally is essential for determining the correct approach. Understanding the problem's context is crucial for accurate calculations.
Jillypilly9
Find the initial velocity of a ball with the time=2.58 seconds and distance of 9.87 meters
vi=v-at
I don't understand how to find the acceleration with just time and distance is it just 9.8 m^3/second?
I can't gather from the problem that the ball experiences any acceleration. The really basic equation that comes to mind is: x=xo+vot+½at2. Give that a try.
In the case that the ball is falling vertically, a=10ms-² instead of zero (9.81ms-² if you wanted to be more precise).
Welcome to Physics Forums :smile:
vi=v-at
How exactly is the problem worded? Is there any indication that the ball is falling?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
