Inquiry on effects surface roughness on Tidal Turbines.
Surface roughness significantly impacts the performance of tidal turbines, particularly due to factors like barnacle growth. Research indicates that increased roughness can lead to reduced efficiency and altered flow dynamics. Several studies focus on the effects of surface roughness on airfoils, which may provide relevant insights for tidal turbine applications. Interns and researchers are encouraged to explore academic databases for papers on this topic. Understanding these effects is crucial for optimizing tidal turbine design and maintenance.
M110020
Hi, I'm an intern in an energy research company and I'm asking if anyone has any links or channels to papers or studies conducted on the effects of barnacle growth or other causes of surface roughness on tidal turbines?
I apologize in advance if I have posted under the wrong part of physics forums. Many thanks for any help provided :)
If you google "effect of surface roughness on airfoils" you'll find some interesting papers ;)
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
9K
