How Does Constant Velocity Change with Different Accelerations?
An object moving with a constant velocity will experience changes in motion based on the direction of applied acceleration. If acceleration is parallel to the initial velocity, the object speeds up. When acceleration is perpendicular, it does not affect the object's speed but alters its direction, as seen in projectile motion. Constant acceleration always perpendicular to the instantaneous velocity can change the direction of motion without stopping the object, as acceleration must have a component in the direction of velocity to affect speed. Understanding these principles is crucial for analyzing motion in physics.
fitchguy316
Describe the motion of an object that is initially traveling with a constant velocity and then receives an acceleration of constant magnitude a) in a direction parallel to the initial velocity, b) in a direction perpendicular to the initial velocity, and c) that is always perpendicular to the instantaneous velocity or direction of motion.
a) Same direction, and would speed up
b) Object would slow down - Something is going forward and has a instantaneous acceleration against it, it would seem to slow down?
c) Object would stop - If something is constantly pressing down on something going forward, it cannot have forward motion, if the magnitude of both are the same. But then again this does not make sense with gravity.
I drew a picture, but with arrows. Here is what my book says, "If an object is initially moving with a constant velocity and suddenly experiences an acceleration in the direction of the velocity or opposite to it, it will continue in a straight line path, either speeding up or slowing down, respectively."
Am I way off? Do you mind explaining this to me?
Hi, welcome to PF.
You're correct about a), but I think that b) and c) are not the right answer. Can you explain your reasoning (preferably for all three of them).
By the way, did you try drawing a picture? Because from your answers I have the feeling that you don't quite understand the situation. But that's just guessing at the problem, you better explain it :smile:
After rereading the caption in the book, I am not so sure it would slow down or stop. The perpendicular may have no effect on the motion of the object at all.
Assuming that "parallel" means in the same direction (and not backwards, which is anti-parallel), then you are correct.
No. Can you think of example of this kind of situation? Here's one: You throw a ball horizontally off of a cliff. The initial velocity is horizontal, but gravity acts vertically. What happens to the speed and direction of motion of the ball?
No. Here's a hint for this one: In order for an acceleration to change the speed of an object, it must have a component in the direction of the velocity. Realize that velocity, being a vector, can change in either of two ways: its magnitude can change (speed up or slow down) or its direction can change.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
