Instructor's Algebra Paradox? : How far does a projectile go up a ramp?
The discussion revolves around a projectile motion problem involving a ball launched at an angle on a ramp. The main issue raised is the instructor's algebraic manipulation, where the variable x is changed mid-equation, leading to confusion about its consistency. The participant argues that this approach is flawed, as it implies that x can take on different values without logical justification. They suggest that a better method would involve maintaining the relationship between x and y based on the ramp's slope. The participant seeks a more coherent way to solve the problem, questioning the validity of the trajectory formula used.
RoganSarine
I'm also working on this other question, which I think my instructor has a paradox in his algebra for lack of what to call it.
Can anyone suggest a logical way to answer this question?
http://media.wiley.com/product_data/excerpt/19/04717580/0471758019.pdf
See problem #43 on page 79
A ball launched with a velocity of 10.0 m/s at an angle of 50 degrees to the horizontal. The launch point is at the base of a ramp of horizontal length D1= 6.00 m and height d2 = 3.60 m. A plateau is located at the top of the ramp.
(a) Does the ball land on the ramp or the plateau?
When it lands, what are the
(b) magnitude
(c) angle of it's displacement from the launch point
The following is all according to my professor
Trajectory Equation
y = tan\thetax - ((g)(x2))/(2vi2)(cos\theta)2
This is what my professor did, but I highly disagree algebraically how this works. The answer is correct, but what he basically does is changes the x variable halfway through the equation:
y = tan\thetax - ((g)(x2))/(2vi2)(cos^2\theta)2
Notice: He divides both sides by x
y/x = tan\theta - ((g)(x))/(2vi2)(cos\theta)2
Ramp of slope = 3.60/6.00 = y/x
Notice: What he is GOING to do is say that the left x is 6.0 (as defined by the question), and then solve for the other x. Why would the OTHER x solve to a different number? They should be the same variable!
3.6/6.0 = tan\theta - ((9.8)(x))/(2vi2)(cos\theta)2
.6 = tan(50) - 9.8x/(2(10cos50)^2)
.6 = tan(50) - 9.8x/82.64
.6 = tan(50) - .1186x
.1186x = tan(50) - .6
.1186x = .592
x = 4.99
Notice: X now equals a different value than it did before, how does that logically make any sense? He now goes to plug the new x value into the trajectory:
3.6 = tan\theta - ((9.8)(x))/(2vi2)(cos\theta)2
y = tan(50)(4.99) - (244/72.64)
y = 5.95 - 2.95
y = 2.99
Thus what?
Thus, the ball lands at the coordinates x = 4.99, y = 2.99
(b) Displacement vector:
Square root[(4.99)^2 + (2.99)^2]
= 5.82 m
(c) tan-1(2.99/4.99) = 31o
Basically, look at this and tell me any more logical way to solve this question because as far as I'm concerned, he did an illegal algebra maneuver to fudge the right answer.
Also, assuming you can solve this a different way, can I basically assume the trajectory formula is a fallacy in physics? I have yet to find a use for it that works besides one question (which happens to be the same as all these other ones).
For y/x he plugged in the slope, a ratio of 3.6/6. That doesn't mean that x is equal to 6 though. A better way to do this with that equationg would be to find out what y equaled in terms of x.
tan\theta _{slope} = y/x
You can find the angle of the slope with
tan\theta = 3.6/6
Then you can use the quadratic formula or just factor out an x and solve.
I understand what he did conceptually, but if you look at the formula he went from... that isn't what happened algebraically.
His "x" did change, and i don't know how that would mean his x didn't equal 6 in the first place.
That's like saying
x=6
y=2
2y = 5x + 6x^2
2y = x(5 + 6x)
2y/x = (5 + 6x)
2(2)/(6) = 5 + 6x
4/6 = 5 + 6x
2/3 = 5 + 6x
2/3 - 5 = 6x
(-13/3) = 6x
(-13/18) = x
However, if I solve for y and graph that equation, I get x to equal (-5/6) and (0) which is NEITHER of those answers.
Again, I don't see how algebraically that works out.
x and y in that equation are variables. You know that the projectile will hit the slope when y/x is equal to the slope which is 3.6/6 aka tan\theta. So therefore you can replace y/x with the slope. That doesn't set x=6 though. x can be any number as long as x/y = 3.6/6
x could be 60, therefore y would be 36. Or x could be 4.99, therefore y would be 2.99.
Yes, I understand that portion... but the portion that makes that bogus to look at is the fact that implies that
Slope = tan\theta - gx/2(vicos \theta )^2
Which... isn't exactly a formula as far as I know. How do you derive the right side (to make his work logical sense)?
Basically what I'm saying is...
y/x = (VoyT + .5gt^2 / VoxT)
Makes sense... but that doesn't equal that tan(theta) stuff that he used... I don't even get how he got that.
The above formula makes more sense.
