Integral Applications: Rate of Change
olicoh
The volume of an air mattress is 15 cubic feet. Air escapes at a rate of r(t)=0.25e^(−0.05t), where r is in cubic feet per second. Assuming the mattress is still completely inflated when the valve is opened, how much air is released in the first 30 seconds?
Here is what I have so far:
V(15) = V(0) + integral[0,15] (0.25e^(-0.05t))
= [-(1/2) (e^(-1/2t))]150 <-- Sorry, I don't know any other way to write the upper/lower bound.
= -2.765E-4 - -0.5
Ugh... My problem with this question is I don't even know what to do for the first step. I just used a formula that was in my textbook and inserted numbers. What is the V(15) and V(0) for anyways? What formula should I be using for this problem?EDIT: I redid the problem and got 0.4997 cubic feet of air is released per second, roughly. Is that right?
welcome to pf!
hi olicoh! welcome to pf! :smile:
(have an integral: ∫ and try using the X2 icon just above the Reply box :wink:)
olicoh said:
… What is the V(15) and V(0) for anyways?
i've no idea :confused:
V(t) should be the volume at time t …
so V(0) = 15, and dV/dt = r
start again :smile:
start again :smile:
Thank you! Oh ok... I don't know. My textbook seriously does not explain any of this stuff to me. they give me equations but they don't provide me an explanation. I'm basically always confused.
olicoh said:
… they give me equations but they don't provide me an explanation.
that's to encourage you to work out the equations for yourself …
have a go :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
