Integral involving square root and exp
The discussion revolves around evaluating the integral \(\int\frac{dx}{\sqrt{e^{x} + 1}}\), which involves concepts from calculus, specifically integration techniques and substitutions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using u-substitution, with one suggesting letting \(u = \sqrt{e^{x} + 1}\) and deriving expressions for \(dx\). There is a mention of breaking the integral into simpler parts, and some participants suggest using partial fractions for further simplification.
Participants are actively engaging with the problem, exploring different methods of integration. There is a progression in the discussion as they attempt to manipulate the integral into a more manageable form, with some guidance offered regarding the use of partial fractions.
There is a repeated emphasis on the need to factor the denominator and find constants for partial fractions, indicating a focus on algebraic manipulation as part of the solution process.
nicnicman
[itex]\int[/itex][itex]\frac{dx}{\sqrt{e^{x} + 1}}[/itex]
Using u-substitution
Let u = [itex]\sqrt{e^{x} + 1}[/itex] [itex]\Rightarrow[/itex] u[itex]^{2} - 1[/itex] = e[itex]^{x}[/itex]
Then, du = [itex]\frac{e^{x} dx}{2\sqrt{e^{x} + 1}}[/itex] [itex]\Rightarrow[/itex] dx = [itex]\frac{2u du}{u^{2}-1}[/itex]
So, [itex]\int[/itex][itex]\frac{dx}{\sqrt{e^{x} + 1}}[/itex] = [itex]\int[/itex][itex]\frac{2u du}{u(u^{2}-1)}[/itex]
But, I'm stuck at this point. I think I want to break it up into two simpler integrals, but I'm not sure how to do this. Any suggestions would be greatly appreciated!
Partial fractions is what you want. Factor the denominator.
Okay.
So, [itex]\int[/itex][itex]\frac{dx}{\sqrt{e^{x} + 1}}[/itex] = [itex]\int[/itex][itex]\frac{2u du}{u(u^{2}-1)}[/itex] = [itex]\int[/itex][itex]\frac{2du}{(u+1)(u-1)}[/itex]
And now I'm stuck again.
nicnicman said:
Okay.
Partial fractions! ##\frac{1}{(u+1)(u-1)}=\frac{A}{u+1}+\frac{B}{u-1}## for some constants A and B. Find those constants.
Okay. I think I've got it.
So, [itex]\int[/itex][itex]\frac{dx}{\sqrt{e^{x} + 1}}[/itex] = [itex]\int[/itex][itex]\frac{2u du}{u(u^{2}-1)}[/itex] = [itex]\int[/itex][itex]\frac{2du}{(u+1)(u-1)}[/itex] = [itex]\int[/itex][itex]\frac{du}{u-1}[/itex] - [itex]\int[/itex][itex]\frac{du}{u-1}[/itex] = ln|u-1| - ln|u+1| = ln[itex]\frac{|u-1|}{|u+1|}[/itex] where u = [itex]\sqrt{e^{x}+1}[/itex]
= ln[itex]\frac{\sqrt{e^{x}+1}-1}{\sqrt{e^{x}+1}+1}[/itex]
Thank you for all your help.
  • · Replies 105 ·
13K
  • · Replies 22 ·
  • · Replies 18 ·
