Integral of (1/(at+b))e^(-t^2)
  • Thread starter Thread starter quantum_2000
    Integral
quantum_2000
I need to calculate the integral of (1/(at+b))e^(-t^2), that is, a negative quadratic exponential divided by a linear function at+b. I need to integrate between some positive x and +infinity.
I could find the integral for b=0. In fact the integral of 1/(at) e^(-t^2) between x>0 and +infinity is equal to -1/(2a) Ei(-x^2) where Ei(x) is the exponential integral function defined as
-Ei(-x)=E1(x)=Integral of (1/t)e^-t between x and +infinity. Since Ei can be expressed through the Incomplete Gamma function and I have the latter in Excel, in this case my problem would be - at least computationally - solved.
However, when b is not zero I cannot find any solution. Any help guys?
Seems like a tough one. Do you have numerical values for a, b, and x? If yes, I would suggest a numerical integration.
The reason why I need an analytical solution is that I need to be able to compute the integral in a single Excel cell for any given set of parameter values. So, say that a=20 b=50 and x=80, I need to compute in a single cell (that means without being able to compute partial results in any other cell or set of cells) the integral of e^-t^2 / (20a+50) between 80 and + infinity.
If I understand correctly what you mean by numerical integration, it seems this would require to launch a calculation with a specific software for each instance, and this is not what I need :(
Any other ideas? Please help!
May I ask where the integral comes from?
It is the integral of the pdf of a normal distribution times 1/t. With substitution I get the integral in the title where b is the mean of the distribution. So, if anyone has a solution to compute the integral of (1/t)*PDF(NormalDistribution(mu,sigma),t) from x>0 to +infinity, this would make me very happy as well.
Now, I could also explain where this comes from, but it is not a short story...
So, in the end no one has a clue about it?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
