Integral of Natural Log Part II
The integral of ln(x+1) can be solved effectively using substitution. By letting u = x + 1, the integral simplifies to ∫ln(u) du. Applying integration by parts, the result becomes (x + 1)ln(x + 1) - (x + 1) + C. The discussion highlights the importance of substitution to avoid circular reasoning in the integration process. This method provides a clear path to the solution without getting stuck in repetitive calculations.
wubie
Hi,
I am still having trouble with taking the integral of the following:
integral of ln(x+1) dx
I am trying to do it by parts but I end up getting stuck. I had no problem doing:
integral of ln x dx
But I can't seem to get
integral of ln (x+1) dx
Let u = ln (x+1) then du = 1/ (x+1)
Let dv = dx then v = x.
So then
integral of ln (x+1) dx =
ln(x+1)*x - integral of x/(x+1) dx
I then though that I would integrate the last part by parts again.
Let u = x then du = dx
Let dv = 1/(x+1) then v = ln(x+1)
So then
integral of x/(x+1) dx =
x*ln(x+1) - integral of ln(x+1) dx.
So far I now have
ln(x+1)*x - [x*ln(x+1) - integral of ln(x+1) dx]
But then all I end up getting is
integral of ln (x+1) dx = integral of ln (x+1) dx
So I am back to where I started. What am I doing incorrectly?
Any help is appreciated. Thankyou.
you know the integral of ln[x] and now u want integral of ln[x+1]?
Is it just me or do I hear x+1 begging to be substituted??
What is wrong with me tonight? I can't see anything. >8(
Thanks stoffer.
Cheers.
no prob. we all have our moments
\int \ln(x+1) dx
let u=x+1
then du=1 dx
so you have
\int \ln(u) du
which is:
now you can apply the formula I gave you in the other thread so you get:
u \ln u - u = (x+1) \ln (x+1) - (x+1)
FYI derivation of the formula:
\int \ln(x) dx = \int \ln(x) * 1 dx
now by parts we have:
u=\ln(x)
dv=1dx
so
du=\frac{1}{x} dx
v=x
so
\int 1 * \ln(x) dx=\int u dv = uv+C_1-\int v du =
x \ln x +C_1- \int x* \frac{1}{x} dx=x \ln x +C_1- \int 1dx = x \ln x +C_1- x+C_2=
x \ln x -x +C
