Integral over a sphere with the dirac delta function
tim85ruhruniv
\[<br /> \underset{\left|\underline{\xi}\right|=1}{\int}\delta_{0}\left(\underline{\xi}\cdot\underline{z}\right)dS_{\xi}=\intop_{0}^{2\pi}d\varphi\intop_{-r}^{+r}\delta_{0}\left(\varsigma\right)\frac{d\varsigma}{r}=\frac{2\pi}{r}\]<br />
The \delta_{0} is the dirac delta function.the following variable substitution has been made,
\[<br /> \varsigma=\underline{\xi}\cdot\underline{z}=rcos\theta\]<br />
I am not really sure whether its over the surface of the sphere or the Volume,
the problem and the solution are given above, I want to know how it has been solved.
What is the Jacobian Determinant for the problem ?
I always end up with 2\pi
hey guys,
thanx a lot but i got it finally.
by the way... i posted this problem in another section too and i don't know how to delete it...
Thanx...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
