Integral problem with natural log ($5 to whoever gets it)
The integral in question is ∫ from 2 to 16 of dx/(2x(lnx)^(1/2)). Participants discuss methods to solve it, emphasizing the importance of showing attempted work before seeking help. A suggestion is made to use a substitution method, letting u = (lnx)^(1/2), which simplifies the integral. There is also a reminder that offering money for assistance is against forum rules. Ultimately, the discussion concludes with a successful resolution of the integral using the proposed substitution method.
formula107
Here's the problem:
find the integral of
dx/2x(lnx)^1/2
In other words, dx over 2x times the square root of lnx.
It has to be evaluated from 16 and 2. I don't know how to say it, but the integral sign with 16 at the top, and 2 at the bottom.
If you can find the answerm and show me the work, preferably two different ways, I will paypal you $5.
The sooner the better.
Thanks
Welcome to physicsforums, formula107.
First, a bit about our rules:
1) Homework help posts should go into the appropriate homework help forums.
2) You should show us the work you've attempted so far when asking for help.
3) You should never offer money in return for our help.
I assume you mean this integral?
\int_2^{16} \frac{dx}{2 x (\ln x)^{1/2}}
- Warren
- Warren
Thanks for the advice. Yep, that was the integral I was trying to describe.
I have attempted it, but I still get confused on what to do with dx on the top.
One more question:
Can I use the same text you are by using the code?<br /> <br /> Thanks
Can you please show us the paths you have already attempted to follow to find this integral? We do not generally just give away answers.
One more question:
<br /> Most certainly. You can click on any mathematical image to see the code that generated it. You can then copy and paste the code into your own posts, editing the code if you want. You can also quote a post to use or modify the code for the equations in that post.<br /> <br /> - Warren
I tried bringing the bottom part to the top, so it makes
\int_2^{16} \dx (2 x (\ln x)^{1/2})^{-1}
With dx on the end, but I can't get that to show.
Then from there I just get completely lost. Is that a good first step?
come on, this is darn easy, donate that $5 to charity.
(Hint: Let y = \ln x)
Yep, I finally got it. I end up with u^1/2, and with the numbers plugged in, I got (ln(2))^(1/2).
Seems right to me!
Just one more question: Is there any way to solve this problem without solving for dx before integrating. I came up with dx=xdu, since du=1/x, but we haven't done this in class yet. Is there a way to solve this using only u and du?
Thanks
Seems right to me!
Thanks
If you do a u-sub, and let u be (lnx)^1/2 it turns into just the intergral of U*DU.
So who ended up with the 5 dollars?
