Is the Integration of xex Correctly Solved?
  • Thread starter ƒ(x)
  • Tags
    Integral
In summary, the function f(x) is not equal to the function g(x) when g'(x)f(x)^{g(x)-1} is not equal to g'(x)f(x)^{g(x).
ƒ(x)
328
Please forgive any formatting errors.
[tex]\int x[/tex]exdx = ?
Is this correct?
= [tex]\int e[/tex]ln(x)exdx
= [tex]\int e[/tex]exln(x)dx
u = ex
x = ln(u)
du = exdx
[tex]du/u[/tex] = dx
= ∫ ln(u)u*(1/u)*du
a = ln(u)u
EDIT: da = ln(u)u-1du
dv = 1/u du
v = ln(u)
= ln(u)u+1 - ∫ [ln(u)]udu
u = ex
= ln(ex)ex+1 - ∫ [ln(ex)]exdx
∫xexdx = xex+1-∫xexdx
2∫xexdx = xex+1
∫xexdx = xex+1*(1/2)+C
ƒ(x) said:
a = ln(u)u
da = ln(u)u-1
:eek: eeks, that's not really how you differentiate that function is it?
Have you tried differentiating this result?
More to the point, does this integral actually exist/converge for all values of x?...Surely you are given integration limits?
Well...I skipped some steps.
a = ln(u)^u
a = 1/u (chain rule) * u (bring down the exponent) * ln(u)^u-1 (subtract from the exponent)
a = ln(u)^(u-1) (simplify)
You can't do that when the exponent is the variable.
Oh...Hm...what would you do then?
make the function e^(something). Then you can use chain rule.
Again, there is an even bigger issue here than you incorrectly differentiating 'a':
To illustrate the problem, I've plotted the integrand for x=[0,3]:
http://img16.imageshack.us/img16/2144/hmmmp.th.jpg
Does it look as though the area under the curve is bounded?
Wait...what's wrong with the way I did it? I'm differentiating with respect to u.
(d/dx)3^x is not x3^(x-1).
what is the integral of x^(e^x) then?
I really doubt you can integrate it indefinitely.
It is unreasonable to expect an antiderivative to exist, when the area under the curve of the integrand becomes unbounded at around x=5!...That means for almost half of the real number line, the integral does not exist.
There is no antiderivative for this function, but if you are given specific integration limits, and the integral is bounded on that interval, you may still be able to evaluate analytically by using a trick or two, and if that fails numerical integration is always available.
So, I ask for the 3rd time; Are you given limits of integration?
[tex]\frac{d}{dx} f(x)^{g(x)}= \frac{d}{dx} e^{\ln(f(x)^{g(x)})}=\frac{d}{dx} e^{g(x)\ln(f(x))}=e^{g(x)\ln(f(x))}\left(g'(x)\ln(f(x))+\frac{g(x)}{f(x)}f'(x)\right)[/tex]
[tex]=f(x)^{g(x)}\left(g'(x)\ln(f(x))+\frac{g(x)}{f(x)}f'(x)\right)\neq g'(x)f(x)^{g(x)-1}[/tex]
What is the formula for ∫xexdx?
The formula for ∫xexdx is xex+1/2 + C, where C is the constant of integration.
What does ∫xexdx represent?
∫xexdx represents the indefinite integral of the function xex.
How do you solve ∫xexdx?
To solve ∫xexdx, you can use the power rule for integration, which states that the integral of xn is equal to xn+1/n+1, where n is any real number. In this case, n is equal to 1, so the integral becomes x1+1/1+1 = x2/2. Then, you can use the chain rule to multiply the result by the derivative of the inner function, which in this case is ex. Therefore, the final answer is xex+1/2 + C.
What is the purpose of the constant of integration in ∫xexdx?
The constant of integration, represented by the letter C, is added to the result of the integral to account for all possible antiderivatives of the function xex. This is because when taking the derivative of a constant, it becomes 0. Therefore, the constant of integration allows for different antiderivatives to be included in the solution.
Can ∫xexdx be solved using other methods?
Yes, ∫xexdx can also be solved using integration by parts or substitution, depending on the complexity of the function. However, the power rule for integration is the most straightforward and efficient method for solving this particular integral.
