Integral with natural log problem
luxxx
Hello,
The problem is ∫(ln x)/(x + x ln x) dx.
I've done most other problems in the set, but don't know where to start with this one. Although we are just learning integration by parts, I'm not sure how this would apply. I can get to ∫u/(1+u) du
Thanks for any help.
luxxx said:
Hello,
When you have multiple versions of the exp and log function, try changing variables by letting w=e^x or w=ln(x) or x=ln(w) or x=e^w. Try those and see what happens.
I think the answer is 1 + ln x - ln ǀ1 + ln xǀ +C, but that's using an integration table.. I'd like to know how you would get there.
Well I did u substitution for u = ln x.
That would work. And note:
\frac{u}{1+u}=1-\frac{1}{1+u}
Ha, yeah I just got that when you responded. Thank you!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
