Integral with sq. root in it again
  • Thread starter Thread starter rock.freak667
    Integral Root
rock.freak667
Integral with sq. root in it...again
Find..
\int x^\frac{3}{2}\sqrt{1+x} dx
Well I used the fact that:
\sqrt{1+x}=\sum_{n=0} ^\infty \frac{(-1)^n(2n!)x^n}{(1-2n)(n!)^24^n}
and well I just multiplied by x^\frac{3}{2}
so I integrated:
\int \sum_{n=0} ^\infty \frac{(-1)^n(2n!)x^(n+\frac{3}{2}}{(1-2n)(n!)^24^n}
and got \sum_{n=0} ^\infty \frac{(-1)^n(2n!)x^(n+\frac{5}{2}}{(1-2n)(n!)^24^n\frac{5}{2}}
\frac{2x^\frac{5}{2}}{5}\sqrt{1+x} which is wrong because if i differentiate it I get an extra term in it
That Series is only valid for |x| < 1. I would let x= \sinh^2 u
that hyperbolic substitution throws me off as it kinda made it harder for me
With that substitution I get: 2\int \sinh^4 u \cosh^2 u du, which I believe is possible through methods similar to its circular trigonometric counterpart.
EDIT: I've just done it, its not as easy as I thought but it is possible. Express all the squares in terms of double angle formula. You should get an answer with an x term, and the hyperbolic sines of 2x, 4x and 6x.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
