Integrals of (-3csc(theta))/(1+cos(theta))
  • Thread starter Thread starter Jessicamgray
    Integrals
Jessicamgray
integrate (-3csc(theta))/(1+cos(theta))
i'm not sure
i tried using u sub. but i got nowhere.
U=1+costheta
Du=-sintheta
i'm not sure
U=1+costheta
Du=-sintheta
The reason why your ##u##-sub doesn't get you anywhere (yet) is because (1) there isn't a ##\sin\theta## in the numerator and (2) we'd still need to deal with the ##\csc\theta##. I recommend that you
(1) Put a ##\sin\theta## in the numerator so that your ##u##-sub at least has a chance of working. Of course you can't just put one there, but you can multiply the integrand by ##\frac{\sin\theta}{\sin\theta}## so that there is one there.
(2) Write the ##\csc\theta## in terms of ##\sin\theta## and see if you can make something happen with what you end up with.
I'd try just u=cos(theta). Then since du=sin(theta)dtheta multiply numerator and denominator by sin(theta). That gives you your du. Now see if you can use trig identities to express the other functions of theta as u.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
