Integrate ln [f'(x)] + ln [f(x)] = 0
  • Thread starter Thread starter ck99
    Integrate Ln
ck99
Integrate z'' + (1/z)(z'^2) = 0 to find an equation of motion
This is a GR problem, using geodesic equations of motion, so I have derivatives of coordinate z wrt some parameter λ, where z is a function of λ, and z'(λ) is the first derivative wrt λ
∫(z'/z) = ln z
I have gone from
to
z''/z' + z'/z = 0
Integrate once to get
ln (z') + ln z = 0
But I'm not sure how to integrate again. Looking at a previous problem (which I have the solution for) it should be something like
1/z = Cλ + D
But I don't know how to get my problem into this form!
∫(z'/z) = ln z
I have gone from
to
z''/z' + z'/z = 0
ln (z') + ln z = 0
1/z = Cλ + D
Use the following two facts.
ln(z') + ln(z) = in(z'z) .
(z2)' = 2z'z .
Thanks for the reply Sammy.
Can I do the following?
Use your tip to say ln (z'z) = 0
Exponentiate both sides to get z'z = e^0 = 1
Integrate both sides to get 1/2 z^2 = λ + C
I don't think this is right because the answer is not in the format I was expecting, eg f(z) = λC + D . . . am I allowed to do the exponential step or do I have to physically integrate ln(z'z) or ln [(1/2z^2)'] ?
What you have in your last post is a first order equation. It's general solution can't be "Cλ+ D" because that involves two arbitrary constants and the general solution to a first order equation will involve only one.
Going back to your first post you have
z''/z' + z'/z = 0
ln (z') + ln z = 0
where you have forgotten the constant of integration. You should have
ln(z')+ ln(z)= C where C can be any number. Now that becomes
ln(zz')= C so zz'= e^C.
Integrate that to get (1/2)z^2= e^Cλ+ D which becomes (1/2)z^2=C'λ+ D with C'= e^C.
That's great, thankyou! I knew it wasn't quite right .. .
Cheers for all the help.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
