Integrate or divide the input impedance for transmission lines in series?
The discussion revolves around the calculation of input impedance for transmission lines, particularly when considering segments of varying lengths and configurations. Participants explore whether to integrate or divide the input impedance when dealing with transmission lines in series, addressing both theoretical and practical implications.
  • Some participants suggest calculating the total impedance of a transmission line segment and dividing it by the characteristic impedance to derive the number of segments.
  • Others propose that the input impedance is dependent on both length and frequency, indicating that changing the location of divided parts may yield different results across the frequency spectrum.
  • A participant mentions that the input impedance equation would change for a lossy line compared to a lossless line.
  • There is a suggestion to use iterative methods to calculate the overall input impedance by considering each section of the transmission line and its load impedance.
  • Some participants express the need for equations that show the interrelations of separate parts of the transmission line, particularly in practical scenarios where multiple lines are connected.
  • Concerns are raised about the challenges of reflections at interfaces with mismatched impedances when connecting different transmission line sections.
  • One participant emphasizes the importance of maintaining impedance close to standard values (e.g., 50 Ohm) to minimize the effects of mismatches.
Participants do not reach a consensus on whether to integrate or divide the input impedance, and multiple competing views remain regarding the best approach to model the input impedance of transmission lines in series.
Participants note that the input impedance is influenced by various factors, including the characteristics of the transmission line (e.g., lossy vs. lossless) and the specific configurations of the segments. There are unresolved mathematical steps and dependencies on definitions that complicate the discussion.
patkood
I have tried divide input impedance for transmission line based on RLGC value divided to N, and take into Zin function, but cannot go ahead.
I do not find any reference showing what is the math relation for total Zin and each parts of Zin.
to be brief:
(1) if we divide transmission line with N equal parts, we could obtain each parts of transmission line by simple divide total RLGC by N? am I correct?
(2) if I have N parts of transmission line with different length(different RLGC), how could we obtain total RLGC? can we add them together?
we can start with simple equation from short and open load as listed in the attached file.
Thanks very much!
total with L, Zin=Z0cot(Belta*L) ,
each part with length equal to L/N, Zin(i)= Z0*cot(Belta*L/(N^2)). i=1,2....N
Not sure if could obtain Zin=Z1+Z2+......Zn
Here I list my problem in the attachment.
Hi. I think you are on the right path with 1). My guidance would be to find the total impedance of L0 and then divide that by Z0 which would get you N.
The question is not clear but I'm guessing the OP wants ##Z_{in}## for different lengths.
I'm no expert but we have (from the Post #1 attachment)$$Z_{in} = Z_0 \left( \frac {Z_L + jZ_O \tan βℓ}{Z_O + jZ_L \tan βℓ} \right)$$The relationship between input impedance and length (given all other parameters are the same) is quite complicated.$$Z_{in}(ℓ=L_0) = Z_0 \left( \frac {Z_L + jZ_O \tan βL_0}{Z_O + jZ_L \tan βL_0} \right)$$ $$Z_{in}(ℓ=\frac {L_0}N) = Z_0 \left( \frac {Z_L + jZ_O \tan β\frac {L_0}N}{Z_O + jZ_L \tan β\frac {L_0}N} \right)$$ $$Z_{in}(ℓ=NL_0) = Z_0 \left( \frac {Z_L + jZ_O \tan βNL_0}{Z_O + jZ_L \tan βNL_0} \right)$$Edited.
Hi Osilmag and Steve4Physics,
Thanks for the help.
I re-think my problem and try to make clear below:
(1) what Steve supplied is correct, but I I would like to know more for different parts within a transmission line, for example, the total lengh L being divided by N parts, their impedance Z(i),i=1,.2..3...N is not independent, each Z(i) has its locations. So I want to find equation for Z(in) that has location variables, only become this we could integrate together to obtain total impedance for the whole line(length= L).
it may be clear to see the below table.
first row is imput impedance for three parts.
second row is supposed for equal divide of Δx.
Third row is supposed for non equal divident.
Second row and third row may have different length in total(just an example).
Z0Z1(x1)Z2(x2)Z3(x3)
location at zero point,x0=0x1=x0+Δxx2=x1+Δxx3=x2+Δx
x0=0x1=x0+Δyx2=x1+2*Δyx3=x2+3*Δy
if we integrate z0 to z3 for the second row with equal divident that seems ok.(also not sure)
if we integrate z0 to z3 for third row, that might be different:
a1) integrate z0,z1,z2,z3
a2) integrate z1,z3,z2,z0.
(2) it would be quite different to obtatin imput impedance If I place one same short connector between z1 and z2, or between z2 and z3.
so if I make clear of the equations for divided parts, I would see through total z from frequence domain to know what is wrong with my connections.(I know we could employ time domain analysis by numerical computation, but the above idea could see from RLGC to build the total transmission, and inteprete more information----problems from R,L,G,C.... )
To add more, input impedance is both length and frequency dependent. so I guess if we exchange location for divided parts, we got different results in whole frequency band.
Sorry to say, as I suppose we could divide and integrate the transmission lines, it is a lossy line not lossless line, so the input impedance equation would be little changed.
It sounds like your asking about the Z parameters of a transmission line segment. Then you can cascade them if necessary, which, of course should give you the same answer as a longer TL. Most people use S-parameters for these, but they can all be converted to the others. There's lots of stuff on the web about TLs. Like these (chosen mostly at random, first good content method, LOL):
https://qucs.sourceforge.net/tech/node61.html
https://upcommons.upc.edu/bitstream...microwave_circuits.pdf?sequence=4&isAllowed=y
Your lumped element model is just an approximation to a real TL. It gets better as you add more sections, but it's never the exact answer. Yes, you should be able to divide by N as you described.
Hi DaveE,
Thanks for the reply and reference.
I still would like to know equations that show interrelations of separate parts.
As the above show divided parts as independent short transmission line.
if I suppose, there being different length of transmission line, and I connect them together to form a new transmission line.
How could I derive the equation?
Ztotal=f(Z1, Z2, Z3.....), Z1,Z2,Z3...can be determined from RLGC and length parameters.
It is important because in reality we frequenty encounter connect multiple lines together and some connections have defects or incorrect connections, I can simulate incorrect connections at various joints by employing the above equation.
It can be a good reference if we find total impedance has abnormanities.
Thanks very much!
patkood said:
Hi DaveE,
Thanks very much!
I think you just have to work through the math for dissimilar lines. There will be reflections at each interface with mismatched impedances. It's kind of a mess for multiple sections, what with reflections of reflections, standing waves, etc. I'm not aware of an easy fix. I do suspect it's easier with s-parameters, but it's been so long since I did any of that I'm not sure. Either way there's no simple solution. In practice, EEs will use simulators for this.
How about this:$$Z_{in} = Z_0 \left( \frac {Z_L + jZ_0 \tan βℓ}{Z_0 + jZ_L \tan βℓ} \right)$$Suppose we have N sections of transmssion line. The i-th section, considered in isolation with its load ##Z_{L,i}## has impedance:$$Z_{in,i} = Z_{0,i} \left( \frac {Z_{L,i} + jZ_{0,i} \tan β_i iℓ_i}{Z_{0,i} + jZ_{L,i} \tan β_i ℓ_i} \right)$$The load impedance of the i-th section is the input impedance of the sections following i-th section. We can use an iterative approach a build-up the overall value of ##Z_{in}##.
a) Calculate ##Z_{in, N}## (the input impedance for the last section).
b) Calculate ##Z_{in, N-1}## taking ##Z_{L,N-1} = Z_{in,N}## (giving the input impedance for last 2 sections).
c) Calculate ##Z_{in, N-2}## taking ##Z_{L,N-2} = Z_{in,N-1}## (giving the input impedance for last 3 sections).
etc.
Eventually you find ##Z_{in,1}## which is the required overall impedance.
Trying to combine the above steps into a single algebraic equation would be unmanageable. But for numerical calculation purposes, a simple computer program would be quite practical.
Edits: cosmetic only.
This might be obvious, but there is a very good reason for why we do our very best to make sure all segments are as close to 50 Ohm as possible(or 75 Ohm if that is what you are using) . Yes, you can analytically handle imperfections using Z- or S-parameters but if you are in a situation where a bunch of "accidental" mismatches have a significant effect on what you are doing it is also very likely the case that the only way you will be able to understand what is going on is by actually measuring the whole line assembly using a VNA or some form of TDR, modelling is not very useful.
There are of course situation where you introduce mismatches on purpose (say in a stepped impedance filter), but typically you are then only dealing with small number of "steps" and the algebra becomes manageable. That said, if your goal is to actually design say a filter you will most likely going to be using Sonnet, HFSS or similar software.
Also, all of this of course assumes that you are dealing with a single mode....If not, it gets very, very complicated.
I definitely agree with the TDR.
  • · Replies 18 ·
  • · Replies 32 ·
