Integrate f(x) = sqrt(1+1/x)
  • Thread starter RyozKidz
  • Tags
    Integrate
In summary, the conversation is about finding the appropriate trigonometric substitution for integration and discussing various methods and techniques to solve the equation.
RyozKidz
how am i going to integrate this one?
f(x) = sqrt( 1 + 1/x )
sorry for not using the symbol.. because not so familiar with that .. ^.^
try substituting tan u = x
does tan u = x work with f(x) = sqrt( 1 + (e^x)/4 ) ?
did you solve the earlier?
it didn't work
if tan u = (e^(x/2)) / 2 would work i guess
waaaaaaa, how come, i get sqrt(4+ex)
thats wierd
how did you figure out ? By intuition ?
sorry , i think i have some mistake on the earlier question i posted .
i forgot to raise the power of x to 2
the f(x) should be f(x) = sqrt( 1 + 1/(x^2) )
sorry about that ..~
Have you figured this one out yet?
owho, if your question sqrt( 1 + 1/x ) then use tan u = sqrt(x)
if sqrt( 1 + 1/(x^2) ) then use tan u = x
hmm, there are many ways, but for me, i imagine of a triangle
sqrt( 1 + 1/(x2) ) = (sqrt(x2+1))/ x
hmm how should i draw the triangle,
or wait until some other explanation people give,
i try scanning my triangle for a while. ngahahaha
View attachment scan0001.pdf
there, hmm how do i choose those values on triangle by intuition i guess, try to make it same as your equation.
im really good in english tough, i hope someone can explain it more detail
haven't ..~ no idea before annoymage replied my post~
annoymage : woww..~ never thought of that methods ...~
In that case, you'll probably find it easiest if you make the substitution [itex]w=\frac{1}{x}[/itex] and integrate by parts once before making the trig substitution annoymage suggested. Give it a try and post your attempt.
I don't think integration by parts will go anywhere.
Integration tables.
You can obtain the the first integration form by substitution.
[tex]\int\frac{\sqrt{a+bu}}{u^2}du=\frac{-\sqrt{a+bu}}{u}+\frac{b}{2}*\int\frac{du}{u\sqrt{a+bu}}[/tex]
[tex]\int\frac{du}{u\sqrt{a+bu}}=\frac{1}{\sqrt{a}}*ln{\left|\frac{\sqrt{a+bu}-\sqrt{a}}{\sqrt{a+bu}+\sqrt{a}}\right|}[/tex]
Dustinsfl said:
I don't think integration by parts will go anywhere...
This is integration by parts. The tables of integrals are derived using the same methods of calculus taught to students.
What does the function f(x) = sqrt(1+1/x) represent?
The function f(x) = sqrt(1+1/x) represents the integration of a function over a specific interval. In this case, it represents the area under the curve of the function f(x) = sqrt(1+1/x) from 0 to a specific value of x.
What is the process for integrating f(x) = sqrt(1+1/x)?
The process for integrating f(x) = sqrt(1+1/x) involves using the power rule, substitution, and integration by parts. First, we use substitution to simplify the function to 1/sqrt(x). Then, we use the power rule to integrate 1/sqrt(x) to get 2sqrt(x). Finally, we use integration by parts to solve the remaining integral of 2sqrt(x).
What is the domain of f(x) = sqrt(1+1/x)?
The domain of f(x) = sqrt(1+1/x) is all positive real numbers except for 0. This is because the function is undefined at x = 0, as the denominator becomes 1/0 which is undefined.
Is f(x) = sqrt(1+1/x) a continuous function?
Yes, f(x) = sqrt(1+1/x) is a continuous function. This means that there are no breaks or jumps in the graph of the function and it can be drawn without lifting the pencil from the paper. This is because all of the pieces of the function are connected smoothly without any gaps or holes.
What are the applications of integrating f(x) = sqrt(1+1/x)?
The integration of f(x) = sqrt(1+1/x) has various applications in mathematics, physics, and engineering. It can be used to calculate the area under a curve, determine the displacement of an object over time, and solve problems involving motion and velocity. It is also used in the fields of economics and finance to calculate the present value of continuous cash flows.
