Integrating by Parts: Solving for Probability in Sphere of Radius a0
  • Thread starter Thread starter unknownuser9
    Integrating parts
The discussion revolves around calculating the probability of finding a 1s electron within a sphere of radius a0, using the provided probability density function. The problem involves integration techniques, specifically integration by parts, and the appropriate limits of integration.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the substitution of variables to simplify the integration process and the application of integration by parts. There are questions about the correct limits of integration and whether constants can be factored out. Some participants express uncertainty about the correctness of their calculations and results.
The discussion is ongoing, with participants providing insights and corrections to each other's work. Some have identified potential errors in calculations, particularly regarding signs and limits, while others are seeking clarification on the integration process and its application to the problem.
There are mentions of difficulties with LaTeX formatting, which affects the clarity of mathematical expressions. Participants are also navigating the constraints of homework rules that may limit the type of assistance they can provide.
unknownuser9
Given that the probability of finding a 1s electron in a region between r and r + dr is:
P = [tex]\frac{4}{a_{0}^{3}}[/tex]r[tex]^{2}[/tex]e[tex]-2r/a<sub>0</sub>[/tex]dr
work out the probability that an electron would be found within a sphere of radius:
i) a0
It hints that substituting x = r/a0 makes it easier to integrate by parts.
So, substituting and cancelling:
P = 4x2 e-2x dx
Integrating by parts:
P = (1/2)x2e-2x + xe-2x - (1/4)e-2x
And then use 0 and a0 as my limits?
Thanks.
Cleaned up your LaTeX.
Tips:
Don't put [ sup] and [ sub] tags inside LaTeX tags.
Use one set of [ tex] and [ /tex] tags for an entire expression.
P = [tex]\frac{4}{a_{0}^{3}}r^2e^{-2r/a_0}dr[/tex]
i) a0
P = 4x2 e-2x dx
Thanks.
Now that I can read the probability expression, I can provide some help. To find the probability of finding a 1s electron in a sphere of radius a0, you're going to need to integrate that probability expression from r = 0 to r = a0.
When you make the substitution x = r/a0, dx = dr/a0. I don't see dx in your integrand (or even an integral at all). You showed the results of integration by parts, but not the work, so unless I duplicate your work, I can't say that your work is correct.
Sorry, i really can't use Latex. I did it in word and this is the best i can do:
Code:
P= ∫▒4/(a_0^3 ) r^2 e^((-2r)/a_0   ) dr
P= ∫▒4/(a_0^3 ) 〖a_0〗^2 r^2 e^(-2x ) a_0 dx
P= ∫▒〖4x〗^2  e^(-2x) dx
P=4∫▒x^2  e^(-2x) dx
P= -1/2 x^2 e^(-2x)+∫▒〖xe^(-2x) 〗 dx
P= -1/2 x^2 e^(-2x)+xe^(-2x) ∫▒1/2  e^(-2x) dx
P= -1/2 x^2 e^(-2x)+xe^(-2x)-1/4  e^(-2x)
So now if i use r = 0 and r = a_0 as my limits i get:
Code:
P= |-1/2 x^2 e^(-2x)+xe^(-2x)-1/4  e^(-2x) |  a_0¦0
P=(-1/2 a_0^2 e^(-2a_0 )+a_0 e^(-2a_0 )-1/4 e^(-2a_0 ) )- (0+0-1/4 e^0)
P=-1/2 a_0^2 e^(-2a_0 )+a_0 e^(-2a_0 )-1/4 e^(-2a_0 )+1/4
Am i close? Thanks.
Ive just realized, I took 4 out as a constant at the beginning. Would i have to mulitply through by 4 now?
It's not that hard to use LaTeX, and it's much more readable that what you have below. For me the limits of integration show up as a rectangular pattern of dots, like this: ▒.
Bring the constants out of the integral.
[tex]\frac{4}{a_0^3}\int_0^{a_0}r^2e^{-2r/a_0}dr[/tex]
To see what I did in LaTeX, click the expression above.
After you make the substitution, use integration by parts twice. After you integrate, undo your substitution. Check your final result by differentiating - you should get back to the original integrand.
unknownuser9 said:
Code:
P=4∫▒x^2  e^(-2x) dx
Code:
Am i close? Thanks.
Yer I know but its never worked on my computer. Even if I copy and paste exactly what you wrote, It doesn't work.
OK thanks, I will try that.
I have hosted an image of my calculations in word (LaTex still isn't working for me):
http://img221.imageshack.us/img221/8241/probof1selectron.jpg
Are my workings right?
When I substitute in the limts, I get negative numbers which I am sure is not right.
Thanks again.
I'm pretty sure you have a sign error.
With the substitution x = r/a (I didn't bother with the subscript on a), I have this integral
[tex]4\int x^2 e^{-2x}dx[/tex]
which evaluates to -2x2e-2x - 2xe-2x - e-2x. I have a minus before the third term, and you have a plus.
Instead of undoing the substitution, you can change the limits of integration. The original limits were values of r, and were 0 and a. Since x = r/a, the new limits are 0 and 1. If you evaluate -2x2e-2x - 2xe-2x - e-2x at 1 and 0, and subtract the two values, you get 1 - 5e-2, which is about .323324, a seemingly reasonable value for a probability.
Yeah, i realized i hadnt evaluated the final integral. When i did i got that result and substituting the limits gave me that answer. Thanks for your help!
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 19 ·
