Integrating factor problems (property of exponents)
darryw
my integrating factor for the DE ty' + (t+1)y = t is mu(x) = e^integ (1+(1/t))
= e^(t + ln|t| + c)
so does this simplify to this...or not?
= e^t + t + c
so that DE becomes:
((e^t) + t))y = (e^t) + t)
and then after integrating...
((e^t) + t))y = e^t + (1/2)t^2 + c
is that correct??
= e^(t + ln|t| + c)
For the integrating factor you don't need the constant.
= e^t + t + c
Or not. Your integrating factor is et + ln(t). This is NOT EQUAL to et + eln(t). There's a property of exponents you need here that can be used to simplify ab + c. What is it?
darryw said:
so that DE becomes:
is that correct??
ty' + (t+1)y = t initial conditions: y(ln(2)) = 1
= e^(t + ln|t|)
= te^t
(te^t)y = (te^t)t
integ ((te^t)y)' = integ(t^2)(e^t)
(te^t)y = e^t(t^2 - 2t +2 + c)
ty = t^2 - 2t +2 + c
y = t-2 + (2/t) + c/t
Your next step was to divide both sides by t to get
y' + (1 + 1/t)y = 1 (*)
This is the equation you used to get your integration factor.
= e^(t + ln|t|)
= te^t
(te^t)y = (te^t)t
Too many t factors on right side. It should be just te^t.
The whole reason for find the integration factor is to be able to recognize the left side as the derivative of something. Multiplying (*) on both sides by te^t, we get
y' te^t + (1 + 1/t)y te^t = te^t
or
y' te^t + (y te^t + y e^t)= te^t
The left side happens to be the derivative of y*te^t, which you can check using the product rule.
So what we have is
d/dt[y te^t] = te^t
\Rightarrow y te^t = \int t e^t dt
Can you continue from here?
I want to clarify why i need to use an integrating factor, to see if I am understanding...
This equation is not separable, that is i can't separate all the t's from the y's. If it were separable it is solvable. correct?
ty' + (t+1)y = t
It is not exact either, so the point of using integrating factor is to make the equation exact. And once exact, I can then follow the steps for solving exact equation. correct?
To be exact, then M_x(x,y) + N_y(x,y) = 0.. That is, derivative of function wrt x + derivative of function wrt y = 0.
is this correct?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
