Integrating the function √(12 -x^2)
Chrisistaken
Integrate the function,
f(x) = √(12 -x2)
n/a
I tried splitting the function up as follows:
f(x) = √(12+x)*√(12-x)
then I tried substituting in,
w=12-x and dw=-dx, to get,
∫-2w3/2(2√12-w)1/2dw
and finally I attempted to use integration by parts on the above integral; however this seems to be a dead end. I know the answer is:
1/2*√(-x^2 + 12)*x + 6*arcsin(1/6*sqrt(3)*x)
I just can't seem to work it out for myself.
Any help would be greatly appreciated.
Regards,
Chris
For \displaystyle \int\sqrt{12-x^2}\,dx use the substitution x = (√12)sin(u), then dx = (√12)cos(u) du .
Then \displaystyle \sqrt{12-x^2}=\sqrt{12-12\sin^2(u)}\,, etc.
As SammyS says, a trig substitution is the way to go here. Since I don't try to remember which trig substitution should be applied, I just sketch a right triangle, labeling the sides and hypotenuse according to the expression inside the radical.
The expression 12 - x2 suggests that the hypotenuse is of length √12, and I can label the altitude as x, and the angle opposite the altitude as θ.
From this I get sin(θ) = x/√12, or x = √12*sin(θ), which is essentially the same as what SammyS is recommending.
Thanks Sammy and Mark,
Will give it a go. Also, I think Mark's the first person I've encountered who's actually given a methodology for determining an appropriate substitution. Thanks :)
Regards,
Chris
Well...
It would seem I have fried my brain with the late nights spent trying to work this out. So far I've got;
∫cos3u.du
and once again, I know the answer (=1/3*sin3u +sinu), but for the life of me I can't figure out how to get there. Is having the function in the form cos3u the right way to go? I swear I'm overlooking something blindingly obvious here.
Regards,
Chris
OK,
Well now I'm trying to use the trig identity cos3x = 4cos3x -3cosx
Sound like the right way to go?
Regards,
Chris
Chrisistaken said:
OK,
Regards,
Chris
That should work fine, but aren't you integrating cos2(u).
Well now I'm not to sure. After substituting in,
x = √12*sin(u)
I got,
dx = √12*cos(u)du
Putting both of these back into the integral I then had,
∫√(12 -12*sin2(u))*√12*cos(u)du
=∫√(12(1 -sin2(u))*√12*cos(u)du
using the trig identity, cos2(u) +sin2(u) = 1
I then realized whilst writing this that I didn't take the square root of the first cos term. Need sleep...
Thanks Sammy
Regards,
Chris
