Integrating the product of a real and a complex exponential
seasponges
\Psi(x,t) = \int^{\infty}_{-\infty} C(p)\Psi_{p}(x,t) dp
is a solution to the Schroedinger equation for a free particle, where
\Psi_{p}(x,t) = Ae^{i(px-Ept)/\hbar}.
For the case C(p) = e^{-(p-p_{0})^{2}/\sigma}
where \sigma is a real constant, compute the wavefunction at time t=0.
\int^{\infty}_{-\infty} e^{-αp^{2}+βp} = \sqrt{\frac{\pi}{α}}e^{\frac{β^{2}}{4\alpha}}
where α is a positive real constant and β may be complex.
2. The attempt at a solution
This is the first part of one questions on a set of QM problems I've been given. I've made no progress with this part, because I don't know how to integrate the product of an exponential to a real number and an exponential to an imaginary number.
What's keeping you from plugging everything in and using the relevant equation/hint?
I can't isolate the p^{2} term.
When I take the treat the integrand as an exponential to a complex power, I wind up with
e^{-\frac{(p^{2}-2pp_{0}+p_{0}^{2})}{\sigma}+\frac{ix}{\hbar}p}
I guess I'm still kind of confused about where you're getting stuck. This is just basic algebra.
$$-\frac{p^2 - 2pp_0 + p_0^2}{\sigma}+\frac{ix}{\hbar}p = -\frac{1}{\sigma}p^2 + \left(\frac{2p_0}{\sigma}+\frac{ix}{\hbar}\right) p - p_0^2.$$ You may, however, find it easier to change variables in the integral first using the substitution ##p' = p-p_0##, and then deal with the exponentials.
Ahh sweet, that's cleared things up a little - many thanks!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
