Integration by partial fractions
Xcron
I started this section off quite well and I did very well on the problems where there are only linear factors but when I got to the problems with quadratic factors, I began getting wrong answers. I though that perhaps I would receive some advice or my error/mistake could be corrected if possible.
The problem is:
\int\frac{4x^4-43x^3+200x^2-442x+383}{(x-3)(x^2-6x+13)}dx
It comes with a small help thing that says: (x-3)(x^2-6x+13) = <br /> x^3-9x^2+31x-39
Ok so the first thing I did was use long division and I got 4x-7 as the answer of the long division. Next I proceeded to do:
4x^4-43x^3+200x^2-442x+383 = A(x^2-6x+13) + (Cx+D)(x-3).
Next, I plugged in 3 for the value of x so that I could solve for A and I got its value to be 5. Next, I plugged in 0 for the value of x so that I could get A and D alone and solve for D. I got its value to be -106, which is horribly wrong for some reason, I think. Next I plugged in 1 for the value of x and solved for C nd its value came out to be 75, which is also horribly wrong probably..I made a mistake somewhere in there I think...after that, I set up the new integral:
[/tex]\int\(4x-7+\frac{5}{x-3}+\frac{75x-106}{x^2-6x+13})dx[/tex].
I solved that and got my final answer to be:
2x^2-7x+5\ln|x-3|+\frac{75}{2}\ln|x^2-6x+13|+<br /> \frac{119}{2}\arctan(\frac{x-3}{2})+C.
This answer is wrong and the correct answer is:
2x^2-7x+5\ln|x-3|+4\ln|x^2-6x+13|+<br /> \frac{9}{2}\arctan(\frac{x-3}{2})+C.If I am making some kind of mistake, then I must be inherently making it because all my other answers to problems with quadratic factors is coming out wrong...please help me.
You should have a remainder after you divide:
4 x - 7 + \frac{13 x^2 - 69 x + 10}{x^3 - 9 x + 31 - 39}
That's an awfully tedious problem.
Yes, I do have a remainder after I divide. After the long division, I have:
4 x - 7 + \frac{13 x^2 - 69 x + 110}{x^3 - 9 x^2 + 31x - 39}
What do I do with it? I was just looking over that because I noticed something about it in the book, but I can't quite grasp what the remainder would be used for..
You'll want to split the remainder into partial fractions and then you can integrate everything.
Ok, I just tried that and I finally got the right answer...I guess that's what my error was. After the long division, I need to use the remainder..heh..
Upon further analysis, I realized that the answer is still wrong, this is why:
after the division and the a^2 + x^2 trig substitution, the integral is:
2x^2-7x+5\ln|x-3|+<br /> \int\frac{16\tan\theta+24-15}{4\sec^2\theta}2\sec^2\theta d\theta
then:
x^2-7x+5\ln|x-3|+8\ln|sec\theta|+\frac{9}{2}\theta
The 8 in front of the natural log is supposed to be a four, anyone know why I have an 8?...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
